I will edit and update this post as I find out or recall more information, please do not quote this post so I can keep the thread clean with correct and up to date information.
These are the available transaxles that can be used as bolt-in replacements.
G25MR -1993-1997 Ford Probe, 1993-1997 Mazda MX6, 1993-2002 Mazda 626
G15MR - 2001-2003 Mazda Protege, Protege 5, MP3, MSP
The 2003 G15MR will have the most recent shift fork and selector hub revisions compared to previous versions, so this is the best one out of them.
Bonus
G35MR - out of the Mazda 3 is in the same family of G-type transaxles, gears and guts out of this gear box may or may not fit. I have yet to test or verify this theory. Someone who has access to one should check it out.
OEM Mazda (made by Exedy) stock non-turbo Protege pressure plate has a 1169 ft lb clamp load (your aftermarket OEM replacements are for this model)
OEM Mazda (made by Exedy) stock turbo MSP pressure plate has a 1350 ft lb clamp load (there are no aftermarket OEM replacements for this clutch, you have to buy this at a dealer specifically for a MSP)
Aftermarket Exedy OEM non-turbo Protege replacement part# KMZ08 does not work on a MSP. You will be putting a non turbo protege clutch on your car if you use this! It will slip guaranteed!
Exedy Stage 1/2 pressure plate has a 1545 ft lb clamp load
Aftermarket performance upgrades
All other aftermarket performance clutches are rated against the non-turbo protege clutch.
Gear Speed Calculator
http://www.kabamus.com/garage/gears.html
Gear Ratios
626 I4
1st: 3.307
2nd: 1.833
3rd: 1.233
4th: .914
5th: .755
Rev: 3.166
Final: 4.105
626 V6
1st: 3.307
2nd: 1.833
3rd: 1.310
4th: 1.030
5th: .837
Rev: 3.166
Final: 4.105
Protege 2.0L
1st: 3.307
2nd: 1.842
3rd: 1.310
4th: .97
5th: .755
Rev: 3.166
Final: 4.105
Bonus
- Use API GL-4/GL-5 75W90 gear oil. 80W90 (use only above 10C/50F) or it will be too thick and will shift roughly in colder climates.
- Only the MSP has the weak LSD option.
- MSP trans has a stronger clutch throwout bearing release fork and larger fork pivot ball
- MSP trans has a different slave cylinder with a 1 way valve
- Some transaxles will have the speedometer gear which are not needed on the MSP, you can leave them in if you wish. The MSP uses the ABS sensors to determine speed.
- Quaife LSD is the best alternative option. Don't even bother using a Phantom Grip on converting open differentials.
MFactory now has one available. - The Quaife fits the MSP and regular Protege axles, thus any Protege M/T axle will interchange as well.
- GTX gears have been fitted to work, but still have failed. The real strong gears are PAR gears, however the problem still lies in the weak transfer case in which high rpm and high power loads cause the case to flex and the clearances for the main and counter gears to shift and grenade the gears. PAR makes bearing cup reinforcements which will help alleviate some of this problem, but not many except for some dedicated drag cars have tested this solution.
- PAR also has a full gearset available for those with unlimited budgets.
- Driveshaft shop used to make upgraded axles, but have discontinued their product application, they may or may not still make custom setups.
- If you have grinding issues shifting into gear, you will have to replace the gear selector hub and synchros together.
- Be weary of using high pressure clutches, they will put undue stress and wear on the hydraulic assembly, clutch release fork, throwout bearing, and the crankshaft thrust washers. The reason I recommend Exedy Stage 1 or 2 is because they do not have as high as a clamping pressure as some other manufacturers. The pressure on the Exedy's are slightly higher than the factory MSP which is already stiffer than a regular NA Protege.
Gear Ratios
626 I4
1st: 3.307
2nd: 1.833
3rd: 1.233
4th: .914
5th: .755
Rev: 3.166
Final: 4.105
626 V6
1st: 3.307
2nd: 1.833
3rd: 1.310
4th: 1.030
5th: .837
Rev: 3.166
Final: 4.105
Protege 2.0L
1st: 3.307
2nd: 1.842
3rd: 1.310
4th: .97
5th: .755
Rev: 3.166
Final: 4.105
