CEL is flashing!!
ride0012
OK the car was running fine then the check engine light came on, got it checked out. They said it is running lean. What can i do to fix that? Then after a couple of days the light started to flash again got it checked. these codes came up P0113, P0171(Lean), P0300. What can i do to fix these problems? Need help ASAP. Thanks.
P0113 Intake Air Temperature Circuit High Input
P0300- random miss fire... (multi missfire is generaly caused by bad plugs, bad wires or bad coil packs... its more then likely the wires or packs imo.)
p0171 system lean bank 1 - ( more then likely 02 sensor, try clearning the MAF, vac leaks?, check WGA)
yeah my engine light was flashing before when i was accelerating but after i got the coils and wires replaced it hasent flashed or went on since
