Are you MS3 guys having to give up using strut tower braces to use this?
Can't answer the question on the MS6's but the MS3 doesn't have a factory strut tower brace and it really doesn't need it either.
Is it obnoxiously loud compared to before you put the ETD on?
I'm curious as to what's limiting this product's use on the MS6. Is it slight dimensional differences? It certainly looks easier to install than a front mount -and less of a pain to pull off if you need to.
Is there a comparable product out there for the MS6?
under normal driving it's loud enough you can't use a handsfree phone and you have to crank up the music. i have a sound meter so i'll be able to get absolutely precise measurements of the exact difference of the ETD on and off.
under WOT is is freaking loud.
your damper may be making contact with the ac line. mine is very close to it but it has enough clearance. just to make sure u have the mazda3mods damper right?
mine is absolutely fine under normal driving. minimal increase in cabin noise. u can hear the belts cranking and the injecters working. its very minimal and have no problems when im on my hands free phone. under wot its more pronounced. but in a good way. friend asked me, "when did you put in exhaust?" lol. nothing too too bad. personally i like it under wot.
recheck your clearance between the damper, brackets and ac lines. that may be making your noise as excessive as you say it is.
either way like i said the benefits are +++!
considering i was the first to post a review of the m3m damper (topic=142532.0 on "that other forum"), yes, i am quite certain i have a m3m damper.
considering i was also the first to mention clearance of the AC line, and moved the AC line to prevent contact, I am quite certain it is not making contact with the AC line. if it touches the AC line, it rattles like **** and you will know it immediately.
i guess some people have different opinions of loud. a lot of people won't like the noise, other people (like you, i guess) enjoy it. some noise under normal driving and FUCKLOAD under WOT -- sounds like the inside of a rally car LOL.
that said, there is virtually no vibration. me? i'd take some vibes as a tradeoff for the noise.
with the m3m etd, your strut tower is now basically directly connected to your engine, which is a structure right up against the cabin. noise? you betcha. you can't defy physics. sorry.
yes it is a massive performance upgrade, wish it wasnt so loud.
oh yeah, the increased traction you get from the etd also means increased torquesteer....
worth the money? yes. just dont buy one expecting a 'minimal increase in cabin noise'.
Is this fine when used alone, or do you still suggest using a RMM with this as well?
This ETD seems a ton easier to install than the weapon-R one. i got the WR one from PG and had to do quite a bit of custom stuff to get it on right. had to grind a corner off the tower brace, add some washers next to the eye bolt on the etd at the engine mount, and had to relocate my a/c line bracket off the power steering brace (cut off a section of pipe hanging strip for that one lol). if anyone's interested in pics on what i did, let me know, i'll post them up (i guess on a WR etd write-up/tips maybe)
it is listed on our website
