Would greatly appreciate anyone's help and/or opinion on diagnosing a quirky rear end noise.
Car is a stock (no mods at all) 06 Speed 6 GT (but was first put in service in 3/07 -- bought as a leftover)... Currently has 19,200 miles. About 7-8 months ago developed an intermittent rear end noise. But the performance of the car has not been affected in any significant way (yet). The noise seems to come from the rear end -- it does not seem to be correlated with any particular factor -- seems random as to when it happens -- happens in any gear, at any speed, also happens in neutral when decelerating/coasting,
happens when the car is cold or hot, happens in any kind of weather, comes and goes -- sometimes is noisy for 5 mins then disappears for an hour or tow hours, then may happen again for up to an hour continously...etc....No real pattern to it. The sound is rhythmic/periodic in nature -- varies with the speed of the car ...sounds like a rubbing type of noise -- the syllables
"rrrrrhhhh" "rrrrrrhhhhh" "rrrrrhhhh" come to mind. Not very loud but very audible if paying attention and VERY annoying.
Car has been brought to the dealer 3x for this problem -- twice they put it up un a lift and found no visible damage or rear end problems -- another time a mechanic took it for a ride with me and, of course, it didn't do it when he was in the car (though people riding in my car as passenger have heard it) -- so the dealer won't do anything for me.
However, 10 days ago -- I had a 4 wheel alignment done at the dealer and ever since then, the noise is no longer intermittent but constant.
I am tearing my hair out because (a) so many things might be causing it (bad bearing -- differential, cv, wheel bearing etc....etc... (b) the one time i will take it to a mechanic and do a test drive I just know it won't occur (c) the noise is SO annoying that I just can't live with it this way and (d) seems like dealer won't do anything until it ultimately causes a "catastrophic failure" (of course that will happen when the car is no longer under warranty ! )
I have included 2 sound files made with a handheld digital recorder from inside the car -- 1 is without the sound happening to provide a "baseline" of noise while the car is at highway speed and the other has the noise clearly audible as a rhythmic "rrrrrhing" which is constant throughout most of the 2nd sound file.
Any help or ideas greatly appreciated
Many thanks,
NWView attachment rearnoise.mp3
View attachment nonoise.mp3
Many thanks,
