I attempted to unbolt the lower control arm but one of the bolts wouldnt come out, even with an impact gun. and i banged the s*** hitting up on the bolt with the nut attached and on the metal and then with the tie rod end puller( some metal fork thing) and none of that seemed to work out either. do i need to remove the engine with the trans connected? thats what mazda told me, but its been puttin me back on my build because ive spent 3 weekends now on just trying to pop this tie rod end off. would i be able to disconnect the tie rod from the other end where it connects to the steering? Im going tp have to replace the one tie rod because the fork ended up tearing up the rubber boot
