mazdacruzer
I have a 02 p5 with ABS problem. ABS and Brake lights were on so R&R'd control module, but not sure if brake lines were reattached in correct ports on the control module as brake fluid ate away paint color coding! I need a few pics of proper brake line poistiong into top of the ABS brake control module which is located below/behind battery, between firewall and back of battery. Shop manual does not denote and I can't locate another P5 close by to look at. Help!
