I am changing the lower control arms on a 99 protege and I seem to have run into a problem.
When i was taking the rear bracket off to get the rear of the control arm out, it seems that one of the nuts on the inside of the chassis has snapped off. It is just turning freely now.
This is the outer bolt on the rear arm bracket. Has this happened to anyone? or is there just a slot that the funt has to fall into.... It happened on both sides of the car.
On the back bracket there are 2 bolts on 1 side and 1 on the other... it is the side with only the 1 bolt that seems to have broken.
Any suggestions... please?
