Page 1950 of 1951 FirstFirst ... 95014501850190019401948194919501951 LastLast
Results 29,236 to 29,250 of 29253
Thread: NEMOC Random BS Thread
  1. #29236
    goes to eleven chuyler1's Avatar
    NEMOC & Rotary Moderator
    2013 CX-9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,586
    Bruce, the few times I did Autocross on Newfound Lake in N.H. with the Boston BMWCCA it was the same situation. Lots of standing around while the AWD cars got pulled out of the snow banks. I was one of the few in my MS6 that didnít need to get pulled out.
    Ashley, nice bike, that looks fun!!!!
    Making more progress on the Rx7 this week. I decided to upgrade the entire fuel system. Because it was a carbureted car, it had a very small 5/16Ē feed and only 1/4Ē return line. I was told that return line is too restrictive for most high pressure pumps and will cause them to fail prematurely. Some people just run -6AN hose all the way to the tank but not me. I decided to learn how to bend 3/8Ē hard lines and add flared fittings.
    And of course Iím the engine bay I cut everything to the correct length so the braided lines would be nice and clean...
    On the REPU I just used an external pump and itís rather loud and annoying. For the Rx7 I decided upon a Holley Retrofit kit which replaces the factory pickup and return allowing for an in-tank pump. This particular kit also comes with a hydramat which helps with fuel starvation in the corners when you are below 1/4 tank. I might not have to run a full tank of gas at the track any more!
    And while I was learning to bend tubes, I added a few hardlines to my vacuum manifold system. I donít recall if I went into specifics with you guys but i am keeping the EVAP system which needs two vacuum ports, the cruise control, which needs one port, and the ECU map sensor will need a port. This manifold cleans up that old rats nest of vacuum lines.
  2. #29237
    Registered Member reut1's Avatar
    2003 Protege5, 1992 Miata
    Join Date
    Jul 2009
    Location
    Wallingford, CT
    Posts
    2,216
    All this work youre doing is pushing me closer and closer to spending big money on my miata. Just waiting to see what/if the bonus from work will be like
  3. #29238
    2013 CX-9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,586
    Amanda is starting to think I wonít drive it once Iím done. Regardless, itís keeping me active and helping me learn new things. Itís certainly not a ďbudgetĒ build, and might be a little overkill for a low power vehicle, but Iíll have everything done should I want to add a turbo in the future.
  4. #29239
    No words bazooka joe's Avatar
    Donated: $40
    Miata & NEMOC Moderator
    2016 Miata Club, 2004 MSM, 2014 CX5 Touring, Honda 1976 XL 175
    Join Date
    Oct 2002
    Location
    wbee ma to NC 2016 Jinba ittai
    Posts
    21,213
    Quote Originally Posted by NETC_Redd View Post
    Bought a toy for the back of the bus. Now I can go anywhere.
    Cool!
  5. #29240
    Donated: $40
    Join Date
    Oct 2002
    Location
    Posts
    21,213
    Quote Originally Posted by chuyler1 View Post
    Work of art Chris! Looks very clean with hard lines!!!
    By the way, Iím going to do Lime Rock this june 13th, Thursday night.
  6. #29241
    Join Date
    Jul 2009
    Location
    Wallingford, CT
    Posts
    2,216
    Amanda is starting to think I won*t drive it once I*m done. Regardless, it*s keeping me active and helping me learn new things. It*s certainly not a *budget* build, and might be a little overkill for a low power vehicle, but I*ll have everything done should I want to add a turbo in the future.
    Im so excited to get back in mine. Hopefully I have now ordered all the parts I need to button my motor back up this weekend, then I can move on to repainting the shelf below brake booster and then the transmission drop for seal/clutch replacement. Spring will be here before I know it
  7. #29242
    2013 CX-9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,586
    Quote Originally Posted by bazooka joe View Post
    I was thinking about the one in May and staying for the weekend, not sure I can make June. Youíre gonna shit yourself, itís an insane track at speed!
  8. #29243
    Donated: $40
    Join Date
    Oct 2002
    Location
    Posts
    21,213
    Well, maybe I should bring a change of clothes! Looking forward to it!
  9. #29244
    2013 CX-9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,586
    Is that from Japanese Car Day?
  10. #29245
    2013 CX-9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,586
    Wiring up the battery...
    Intake is on for the final time with all the vacuum lines and throttle cable cut to size.
    Test fitting the new fan kit. It came with a shroud but I had to make some modifications.
    Tonight I need to attach the brackets and wire it directly to the battery. It comes with a built-in sensor and controller that will run at variable speed based on demand. Should be quieter than the fan I put on the REPU.
    Still have a bunch of wiring to finish for the ECU but getting very close to first startup.
  11. #29246
    Join Date
    Jul 2009
    Location
    Wallingford, CT
    Posts
    2,216
    Really making me wish I spent the money on silicone hoses rather than OEM. Main reason I didnt is that my heater hoses and radiator hoses were already "new" (4 years old with maybe 10k on them). So I just decided to keep it boring OEM black!
  12. #29247
    2013 CX-9
    Join Date
    Mar 2003
    Location
    Live Free or Die
    Posts
    12,586
    Yeah, Iím fully committing to the red white and blue theme.
    Been in the garage every night this week. Wired up power to the fan, and started on the new ECU mounting bracket and harness.
  13. #29248
    Registered Member Reitrof's Avatar
    Donated: $50
    2008 Miata PRHT; 2018 3
    Join Date
    Jan 2003
    Location
    Ottawa ON
    Posts
    7,497
    Nice Chris. Looking good.
    I wish I could work on mine, still in storage surrounded by snow!!
    Bruce
    2008 Miata Touring PRHT True Red, MazdaSpeed body kit
    RB Intake, RSII Exhaust, RX8 Sways, KW V3 Coilovers, Fiaam horn
    RX7 FD Rims, Kenwood DNX7100, Int Wiper Mod, 3M Bra
  14. #29249
    Donated: $40
    Join Date
    Oct 2002
    Location
    Posts
    21,213
    Looking forward to seeing all your work in person!
  15. #29250
    Join Date
    Jul 2009
    Location
    Wallingford, CT
    Posts
    2,216
    oh mahk, still quoting replies and not editing out all the pictures. What are ya, an old man or something???
    Slowly putting the miatas motor back together after the timing belt, water pump, crank/cam seals. Valve cover is back from powdercoat. Hoping to have it running this weekend, then Im away for a week. Once im back I will start digging into the clutch and rear main seal swap. Decided now that I am back with the car in CT I really need to put more money into the car to cheer me up due to the fact that I am back in CT :P
Similar Threads
  1. CT Random Thread
    By RenesisKing in forum Global
    Last Post: 06-18-2011, 11:35 AM
  2. Random Video Thread
    By LinuxRacr in forum Lounge
    Last Post: 09-07-2009, 07:28 PM
  3. Random MSP thread!
    By pip7441622 in forum Mazdaspeed Protege
    Last Post: 11-04-2004, 10:28 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
