Metallic36
- 2003 Mazda6 3.0L Speed Yellow
My car is at the shop still, just one small issue remaining. This issue happened when I had the car stock (with stock turbo), with the Unichip, and now with the mods I have (and the GT28RS). It isn't building boost, and when you push the gas, it seems to cut out at 4000 rpms and bucks.
The tests have been done:
It is getting enough fuel, 440 cc injectors and the stock ones still have the same result.
The wastegate actuator, turbo, wastegate, etc. is all working correctly and has been tested.
The MAF is putting out the correct amount of voltage.
They did a test that shows the spark on each cylinder, and two of the cylinders showed a higher scale than the other two.
They are thinking it's something in the ignition, making it cut out somehow.. anyone have thoughts? The ECU has been reflashed, that was before I bought the car.
We ran it with just the stock ECU, and with the AFC. It does run better with the AFC, but still wants to cut out unless you ease it into the throttle, then once you get past that cutout mark it goes into boost fine. It's just getting it there.
