Tools needed:
-new razor blade
-1-2 cans of brake cleaner
-safety goggles
-3/16 steel punch
-Red Locktite
-Ultra Gray RTV
-10mm, 12mm, 14mm, 32mm sockets
-inch lbs. torque wrench
-foot lbs. torque wrench
-new razor blade
-safety goggles
-3/16 steel punch
-Red Locktite
-Ultra Gray RTV
- Remove ALL RTV with a razor
-Clean bellhousing and outer transfer case housing with brake cleaner (use safety goggles!)
-Allow time to let housings dry
- Replace differential
- Replace steel ball, spring, knuckle edged piece (with the roll pin hole side up)
- Align shift forks
- Combine shift forks with gear sets (out of transmission)
- Set the gear set assembly into position
Note : Do NOT break the plastic oil funnel!
-Wiggle the differential to allow the gears to slide into place.
-Insert steel punch into roll pin hole
- Insert reverse gear, then reverse gear shaft
-Make sure that the arm is inside the grooved edge.
- Insert reverse arm rod (dimpled side facing out)
-Check shift fork alignment
-Apply threadlock to bolts
-Torque bolt to ___ ft. lbs.
-Check reverse arm rod alignment
- Remove steel punch and insert roll pin into the knuckle edged piece
- Check shift fork alignment
- Replace magnet
- Make sure that the reverse gear shaft hole is facing outward
- Replace oil channel on outer transfer case housing (10mm bolt - ___ ft. lbs.)
- Apply RTV on the inside edge of all of the bolts (3/8 continuous bead)
- Check shift fork alignment!
- Replace outer transfer case housing
-Finger tighten (15) 14mm bolts and let RTV cure (1 hour minimum)
-Torque the (15) 14mm bolts to __ ft. lbs.
- Replace:
-Reverse gear shaft lock bolt
-Ball + spring (reverse gear tensioner)
-Shift fork shaft lock bolt
-Reverse gear sensor (if removed)
- Slide main shaft collar onto the main shaft
-Replace fifth gear selector + fifth gear onto main and secondary shafts
-Insert roll pin into the fifth gear selector
-Apply threadlock to locking nuts
-Torque locking nuts to 90-140 ft. lbs.
-Using a punch, hammer the ring to lock the nuts onto the main and secondary shafts
-Take extreme care to NOT break the black plastic oil channel!
- Apply RTV to case
-Replace fifth gear cover
-Finger tighten (9) 10mm bolts
-Torque to __ ft. lbs. after an hour - Press in new oil seals for the axles
