Did you know that the standard rod blot on the F.S engine elongates under acceleration. And even worse when boost is applied. This is one of the main reasons our engines go. Mack from Emerald Performance who has done my engine install, has spoken to some of the best engine builders in Aust.(nailbyt) They have re built many blown engines with this fault.
This was what happened to my engine, you could loosen the bolts on the #2 and 3 rod. So if anyone who is running their original block, you are driving on borrowed time. So by the time you hear it. It's too late.(attn)
I would suggest to take the time pull the lower part of your engine and check your rod bolts. And if you can up grade to ARP and new bearings.
