cougar10agREDUX
- 2003 Protege ES-T
finally got around to doing my brakes. noticed the fronts have brembo stamped on them while the rears just said made in italy
BTW i forgot to write the part numbers down but when i go home again i'll post up the part numbers for the brake hardware kits since it took me a while to find. go figure the tiny hole in the wall multi-manufacturer dealership in greensboro knew exactly what i wanted.
the kits consits of:
Front - 4 M springs, 4 guide clips (go on the top and bottom of the bracket that the pads sit in. these should be replaced with every brake job)
Rear - 4 guide clips, 4 shims
both kits came to like $30-40 total. dunno why the fronts didn't come with shims. my EBC pads came with these badass adhesive shims so i only reused the metal plate/shim thing that goes on the front inboard pads that the piston contacts.
