Help w/ Fog Light Wiring
sheldon
2003 Protege ES
Hi everyone,
I'm new to the forum and I'm having problems with my fog lights (03 Protege ES). I wanted to replace my stock bulbs with some yellow ones and after installing the yellow ones, my fog lights don't work anymore. I replaced the stock bulbs and still no luck. I checked the fuse box under the hood and it looked like the fog light fuse was ok.
Is there any other fuses, connections, etc. that you guys can recommend checking? I checked the plugs that are near the fog lights to ensure that they were snug...
Thanks for the help!
yup, made sure both bulbs were securely plugged in (inside the light assembly) and check both of the external plugs were on tight...
Latest posts
