fatti03msp
Contributor
- 03 MSP & 91 RX-7 & 00 1500
ok so here is my problem.
My car was running good, i did the 1.8L coilpack conversion and added some new NGK plugs. I gapped the plugs to .028 and installed them at the same time. After i did that my car was having a real rough idle and would stall when i would first start up the car for the day. It felt like i was running a piston short or something cause i had to ride the clutch to get it moving. So i went like that for a week just hoping it get better, but i didnt.
So with the same setup i installed the perrin fuel rail and it ran even worse lol. so i looked at the my plugs which where in the car for lil under 2 weeks and they where a lil white and the piston 2nd from the left was more white then others. so i switched back to the stock coils and wires hoping that it would fix the problem and it was a lil better but not by much.
So today i got new plugs and gapped them at .030, installed them and the car is still running rough, i was at a 450rpm idle a couple of times and then it just stalls. But once i start moving its fine and the car has a semi miss a lil bit, when i come up to a light or stop sign but its not a horrible real bad miss. But when i get on it everything is fine, boost is good, vac is good when im just coasting in a gear and my A/F ratios are how the normally are. Also i dont have to ride the clutch anymore to pull out so that is a plus.
Me and my one buddy who is a tech can figure out what the hell is wrong with the car, if anybody has any suggestions that would be great and thanks for taking the time to read this long post. Whoever can figure it out my problem if there is one ill send you a zoom-zoom-boom decals im getting made for me lol.
