CorkSport.com is MAZDA PERFORMANCE!
View Poll Results: which suspension upgrade?
Voters
97. You may not vote on this poll
  • BC Coil Overs
    47 48.45%
  • Mazdaspeed Coil Overs
    44 45.36%
  • Autoexe Tunable Suspension
    6 6.19%
Page 4 of 4 FirstFirst ... 234
Results 46 to 55 of 55
Thread: Mazdaspeed coil overs vs. bc vs. autoexe
  1. #46
    Registered Member destrux's Avatar
    2007 Mazdaspeed3 GT Black Mica
    Join Date
    May 2007
    Location
    Tamaqua, PA
    Posts
    219
    Oh I see. Does anyone know if the MS coilovers are stainless steel or not? I'm kind of set on the stainless, cause I drive mine year round and it sits on the street in the winter when we get heavy snow, and I don't want the coilover threads to seize.
    07' Mazdaspeed3 GT Black Mica - basic bolt-ons
    87' Supra Turbo - 1JZGTE swap & lots of weight reduction
  2. #47
    They certainly look like they are constructed exactly like the KW bits:
    I'm assuming they are stainless steel.
  3. #48
    Registered Member
    Join Date
    May 2008
    Posts
    434
    The more research I do on MS coilovers, the more they appear to be very similar to KW V3's. The only major physical difference, from what I'm told, is the black threaded collar that limits how much you can drop the front (which can apparently be removed). Beyond that, MS coilovers apparently have a rate of 400/290 over 375/260 from KW. And the valving is apparently the same.
  4. #49
    ---Fogged Out--- FOGMIC 3's Avatar
    Cosmic Blue Mazdaspeed 3
    Join Date
    Nov 2008
    Location
    San Mateo, CA
    Posts
    318
    I hear lots of great reviews from local members and on the boards in regards to H&R's for the MS3, in fact I may get a set in the coming months.
    COBB SRI | Black FORGE BPV | ROTA SVN's | Smoked Side markers | 20% Tint | 6000k 55w HID's | Shark Fin Antenna | CF Spoiler Lip
    Nick: The most amazing person alive with a huge penis - Urban Dictionary
  5. #50
    Join Date
    May 2007
    Location
    Tamaqua, PA
    Posts
    219
    All KW street coilovers have a fairly conservative lowering limit (well, it's only conservative if a 2+ inch drop matters to you) to allow the parts to be street legal in europe. It mentions about it on their website. TUV sets standards for coilovers as to how far they can allow the car to be lowered and still remain street legal. I guess it keeps the ricers in check over there.
  6. #51
    Registered Member
    Join Date
    May 2008
    Posts
    434
    Quote Originally Posted by FOGMIC 3 View Post
    For daily use, I'd choose H&R's any day of the week. Most of their apps are about 50% stiffer over stock with slightly more progressive spring rates. The only reason i'm considering MS coilovers is because of their adjustability. H&R uses threaded Bilstein Sports which aren't adjustable.
  7. #52
    Registered Member
    1989 Mazda RX-7 Turbo II
    Join Date
    Jan 2008
    Location
    Irvine, California
    Posts
    14
    Quote Originally Posted by 7mileshome View Post
    I have the mazdaspeed coilovers, and I love them. I have tracked them a couple of times, and they are absolutely worth it. Independant compression and rebound adjustment (16 ways +/- for both.) It does lower the car, but not as much as the BCs, that is too low. The mazdaspeed coilovers are the KW varant 2s, they are just rebadged as mazdaspeeds.
    Basically for anyone doing research:
    If you are into performance/racing, and auto-x, GET the mazdaspeeds!! There is a reason that club mazda uses them!
    If you just want something to really lower your car, get the BC.
    P.s. - If you call a vendor looking for advice on which set-up to go with, just keep in mind that their goal is to get you to buy something. Talk to someone that actually knows something about suspension for advice. = )
    The KW Variant 2 is only one adjustment, the KW 3 has compression and rebound, so I think the MazdaSpeed are actually the variant 3 struts, but I could be wrong.
    SportsCompactCar (RIP...) did a great suspension comparison in 2008 w/ both BuddyClub and KW. They did use an S2000, but the comparisons are still valid. They liked the KW ClubSport best for street and strip. The ClubSport is the V3 KW w/ different upper mounts and more aggressive dampening profiles. Given that I am autocrossing a lot, I'm going with the MazdaSpeed.
    LASTLY - if you do autocross, you're eligible for MazdaSpeed MotorSports Competition Parts discounts. I'm calling for pricing tomorrow, but basically you show them two race/autocross results, and they sell you parts at ridiculously low prices. Very cool...
    Cheers,
    Collin Webster
  8. #53
    Quote Originally Posted by FCNutCase View Post
    Cheers,
    Collin Webster
    You're correct.
  9. #54
    Registered Member
    2010 Speed 3
    Join Date
    Jan 2010
    Location
    Hickory, NC
    Posts
    597
    Does anyone have a pic of the lowest setting on the BC set up?
  10. #55
    Sesquipedalian Redline_Tuner's Avatar
    2010 CBM Mazdaspeed 3
    Join Date
    May 2013
    Location
    Euless
    Posts
    23
    MSM (Mazdaspeed) Coilovers are re-badged KWv3s that are dialed in perfectly for our cars by Mazdaspeed. They are a FAR superior coilover to BCs in so many ways. And if you're a member of MSM, you can get them for literally like a grand less than KWv3s.
    No contest...
    (Couldn't resist the thread necro )
    FREEK'D FTW! | 93 Octane: 325/340 | E28 Mix: 390/385
    COBB AP | Autotechs | BNR S3 v1 | CM10 Spraying 100% Methanol | HTP 3.5" | JBR Piping & TR8C | Synapse DV | Full 3" Custom Exhaust | Stratified 3-Port & GA v2 | 3-Bar MAP
    JBR Rear Sway Bar | GC Coilovers 375F/430R with Koni Yellows | SPC Arms | Stoptech Lines | CS Pads
    JBR 88d RMM/80d PMM, IM & TB TIGs, Coolant Bypass, SSP, Bushings, & Knob | MD OCC
    245/40 - 17 Michelin PSS on MB Weapons | Rolled Fenders
Similar Threads
  1. Driving Impressions:2006 Mazda MazdaSpeed 6 (A/W)
    By mikeyb in forum Mazda6 General
    Last Post: 02-03-2006, 07:26 PM
  2. Ground control coil overs
    By mikesmazda155 in forum Mazda Protege
    Last Post: 06-10-2002, 11:35 AM
  3. best price on gc coil overs
    By protege5zoom in forum Mazda Protege
    Last Post: 02-01-2002, 01:25 AM
  4. skunk2 coil overs
    Last Post: 12-17-2001, 10:40 AM
  5. Coil Overs...Lowering the Car?
    By KurtMP3 in forum Mazda MP3
    Last Post: 11-13-2001, 09:10 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
