mathblaster
- 1988 Mazda 323 GTX
I think I blew the head gasket on my GTX. I was driving along the highway going up hill at 70mph. I lost a little power then a lot more, it stuttered a bit. Luckily I was just at an exit and pulled off. There was white smoke from the engine and then a puddle of coolant under the front drivers tire. I can't see a coolant hose that burst/came loose. I do have a MBC that is set to 9.5 psi, its below the factory fuel cut off.
Is there anything I can check that will tell me it is definitely the head gasket?
I guess I'll get a cometic gasket and ARP studs. Is there anything else I should look into? And how hard is it to swap the head gasket? I do have a shop manual on CD.
Thanks for any help.
