Check tes endlinks de sway bar for starters.
What kind of sound is it? Is it a squeek or a clunk or etc.?
Its more like a clunk, no squeeking!
check your sway bar bushings and endlinks.
I would inspect the swaybar end links jacking the entire front end (one jack on each side + jack stands for safety). My driver side swaybar link was rock solid while on the ground, but it was pretty loose when both wheels were off the ground. Fixed my problem with AWR end links and new swaybar bushing. Good luck!
Know what I found? 2 Loose nuts that hold the hood to the hinges. That was what was causing the rattling sound. You could look for those.
Ill check that as well... thanks!
Did you find what was causing this? I have the exact same sounds. I know my bushing probably need replacing but my endlinks are pretty new.
