Hey guys, haven't posted in a while. My baby finally has a problem and I am curious to see if anyone else had the same thing. I hit 100k in January. Never had a problem.
Drove to the airport to pick up my parents, idled "under" the airport for about 5-10 minutes with A/c on while waiting. After I picked up my parents, I noticed that the a/c was blowing warm air. Didn't notice/don't remember if it was warm while i idled. I turned off the a/c, got on the highway, drove to my grandmas (about 25-30 miles) and when I parked i noticed that the gauge read higher than usual. In 7.5 years of driving i have never seen the gauge move from it's "normal" spot. 15 minutes later I added just a little bit of water to the overflow tank and radiator. Started driving and 4 miles later the gauge went through the roof, I turned off the car. I waited for a while for the car to cool. Then added more water and drove home (another 5 or so miles) without a problem, and gauge red normally all the way.
My commute is 10 miles with 4 of those being on the highway. Every time I drive, the temp gauge reads normally. It doesn't move. But when I come to work, I check under the hood, and the overflow tank is full to the top with coolant. My radiator does have a small leak right where the spout is (where you pour the water into it) attaches to the radiator itself. The coolan't "sips" out, but it does not leak out. Also, when i turn on the car and watch the overflow tank, I see bubbles rise up inside.
Maybe the thermostat is bad? but the temp would be higher. 15-20 minutes of driving, some of it on the highway, is more than enough for the engine to reach normal operating temp so that thermostat opens. If the thermostat didn't open, then the coolant in the overflow tank would not be hot either, since it never makes it inside the engine, right? Could it be the cap not keeping pressure or because of the small crack? I tried replacing the cap with one from advance auto parts and after doing the same commute, i checked under the hood and i thought the overflow tank would explode. the coolant was literally boiling inside of it. so much so that the overlow tank that i replaced 2 weeks ago got slightly deformed.
anyways, sorry for the long story. any ideas? suggestions? should i try a cap from the dealership? should i replace the radiator? where do you recommend getting a radiator? i don't plan on getting rid of the car anytime soon.
