I am normally cruising at around 2,000 rpm or below in 6th, sometimes 5th if traffic is slow along the backroads. I stay off the turbo for most of my driving (for real) attempting to maximize gas mileage. Only seeing 22/23 mpg. (nuts) I took a 150 mile drive to my girls parents house 2 weeks ago and got just shy of 27mpg. I've got about 1,400 miles on my motor if it makes any difference. Will this get better with time???
another important thing to remember is: use engine braking! when you engine brake on a fuel-injected car, you're basically not consuming fuel and still moving forward. it saves your brake pads and also adds to fuel efficiency. i consistently get 22-24mpg on mixed driving with my car and 28-30mpg on the highway now because i'm used to keeping my RPMs where i mean for them to be. when i'm going through stop and go traffic, i allow myself to rev up to 3k-4k rpms (without going heavy on the throttle so the turbo stays off) so that i have plenty of engine braking available for slowing down at lights and because of slow traffic.
in the end, there isn't a magical "fuel efficient RPM" that you need to stay at...it's a combination of RPM management so that you can stay in the zone for engine braking, cruising, etc.
Why is engine braking more fuel efficient than coasting? If you are coasting you are at idle RPM which is less than when the engine is engaged while slowing down. Also, while you are putting less stress on brake pads, you are putting more stress on the transmission and engine downshifting, right? Brake pads are easy to replace.
when you idle, you're actively burning gas to maintain the 700-800 rpms that the engine turns at. when you engine brake on a direct-injection car (synonymous to taking your foot off the accelerator), your car basically stops injecting fuel into the engine cylinders. what keeps the engine rolling at X rpms is simply the forward momentum of the car traveling through the transmission and into the engine. in order to keep the engine turning without detonating gasoline in the cylinders, it bleeds off the kinetic energy from the car's forward movement (thus the "braking" effect).
now, i should have mentioned that i do not downshift just to engine brake, since that would indeed be unnecessary wear on the transmission (which is why i was trying to emphasize the careful management of RPMs so that you have enough engine speed handy for effective braking without downshifting). if you don't downshift to engine brake and simply take your foot off the accelerator, the wear to the engine and transmission is negligible. i mean, if you think about what your engine+transmission is built to handle (hard acceleration created by blowing up loads of gasoline crammed into the cylinders with heavily-compressed air), engine braking is a complete cakewalk! where you run into noticeable wear on transmission parts is when you shift gears, disengage/reengage the clutch, etc. when it's fully engaged and running, the wear is basically negligible.
Engine braking by downshifting does not cause any harm to the transmission. There is no more wear on it (in fact there is less) than when you are at a similar RPM / gear and accelerating. This is because you are braking at the same time to assist the transmission in slowing down the vehicle. Larger vehicles have been doing it for decades. In fact, newer large trucks have automatic engine braking built in. The slight increase in wear on your transmission is more than worth the amount of wear you will save on your brakes and rotors. I alway engine brake. (now) I have never had a transmission issue on a car ever, and my brakes last a heck of a lot longer than before I did it. In many cases at slower speeds, I never have to touch my brakes.
One more thing, it is the fact that you take your foot of the gas that causes modern vehicles to shut off the fuel. The RPM level (being in or out of gear) is irrelevant. Therefore, it is better to engine brake for the sake of your brakes, as it will not affect your MPG either way.
Oh, I see. I think this explains why when I let my foot off the accelarator when in gear, the ignition timing in my other car (not a Mazda) drops all the way down to 3 (It's 15 at idle), and the fuel injector pulse % drops as well.when you idle, you're actively burning gas to maintain the 700-800 rpms that the engine turns at. when you engine brake on a direct-injection car (synonymous to taking your foot off the accelerator), your car basically stops injecting fuel into the engine cylinders.
my understanding was that your engine will always try to maintain a minimum of idle RPM. if you're above idle RPM, then my understanding was that it will actually pull fuel a little farther past what it does to maintain idle. given that, if you engine brake instead of braking with your pads + rotors, you would actually save some gasoline too. if i'm wrong on the additional fuel cutting thing, then you're definitely right about the brakes being the only thing saved.
I flog the s*** out of mine and get a whopping 16mpg
