Hey guys, name's AliasJerk, I hail from the Contour.org (CEG) forums, as a fellow motoring enthusiast.
However, I have a friend I work with that has an '03 Protege5 (85K miles) that has a knocking sound coming from the suspension. He informed me that about a year ago they had replaced the front sway bar (or possibly endlink? He wasnt entirely sure) and the same sound came back.
Heres how I can describe the sound, when ever you go over any sort of uneven road there is a knocking noise coming from the driver side, in my experience in car suspensions, I think it is the strut or strut mount, because its not just a quick rattle or knock, it sounds almost like its "bouncing" initially I wanted to say his sway bar endlink was bad.
Another thing I noticed I pushed down on the car's suspension and you could kinda hear the same noise when you would do the "bounce" test on the suspension, just wasnt as noticeable. Along with doing that test, the car took like 2-3 rebounds before the suspension would settle again. I told him he probably needs new front struts and mounts, because you are supposed to replace both fronts and both rears at the same time.
The car rides absolutely fine, and it seems strange to me that after 85K miles the struts about be THAT bad, unless there is something about the protege5 I didnt know. I told him I would search the internet and get back to him, but he wants me to help him fix it, so first step is finding out whats wrong, 2nd step is finding out how difficult it is to swap out.
I've done Contour SVT suspensions, and those are a PITA, so there certainly cant be anything worse then that.
Thanks in advance guys.
