eney ways the info i got what i need is,
You don't need to replace the cross member it's the same.
you'll need the trany,axels,2 lower suspension A arm,booster and master cylinder, engine harness and cpu from the 1.8L V6.air flow meeter, cluster.
If you don't want to have the front to low you could take the shock from the precidia V6 too they are 1/2 inch higher.
