PnP Standalone engine management
Aricjm15
05 MSM
I need a list of how many people would be interested in a standalone solution for tuning these cars. The unit would provide complete control over all aspects of fuel, timing, cam timing, throttle plate control, and everything else you could think of. The unit would hooked in parallel with the factory ECU and the factory ecu would keep control of all CAN functions (gauges ect).
The unit we would be using would be the Hydra Nemesis.
Here is a little more info about the unit.
  • New Extruded Aluminum Enclosure with updated software.
  • Dual 16bit 25MHz Processors
  • Plug and Play
  • Windows programmable Software w/ Direct Serial cable Connection
  • Uses All Factory sensor.
  • Retains all factory functions
  • EGR
  • Purge Control
  • Power Steering
  • Coolant and AC Control
  • Factory Intercooler Spray, EVOVIII and Sti
  • Air Conditioning
  • Boost Control
  • Idle Speed ( Both Solenoid and Stepper Types)
  • Cold Start Compensation
  • Acceleration and Deceleration Enrichment
  • Wideband )2 Air/fuel Long and Short term Control
  • Programmable Closed Loop Knock Control
  • Check Engine Light Control
  • Backup Spark tables for Limp mode
  • Fuel map 32 by 32 grid styled
  • Ignition Map 32 by 32 grid styled
  • Two Mappable Variable 3D Cam Maps 24 by 24 grid styled (VTC/AVCS/VVTi/Vanos)Closed Loop true cam timing by degrees Soon
  • Aux 3D Fuel Map 32 by 32 Grid Styled with switched input (For Dry NOS or Race Gas)
  • Aux 3D Ignition Map 32 by 32 Grid Styled with switched input (For dry NOS or Race Gas)
  • *3DAntilag Fuel Map 32 by 32 Grid Styled with switched input
  • *3D Antilag Ignition Map 32 by 32 Grid Styled with switched input
  • built-in 3 bar map sensor replaces all MAF or AFM with Speed Density for up to 30psi (up to 45 psi with optional 5 bar map sensor)
  • Full Sequential Fuel injection and Ignition control for up to 8 cylinders
  • Drives all types of injectors without the need of a ballast box (peak & hold and Saturated)
  • Individual Fuel Injector Trim
  • Injector Phasing
  • Wide Band Closed Loop Lambda Control for true Auto mapping of Air / Fuel 32 by 32 Grid Style (requires Optional software upgrade and NTK L2H2 Wideband Oxygen Sensor)
  • Continuous Closed Loop Air / Fuel Correction 32 by 32 Grid Style (requires Optional software upgrade and NTK L2H2 Wideband Oxygen Sensor)
  • Tachometer Drive
  • Coolant temperature and Air Temperature correction for Fuel and Timing.
  • Barometric Compensation for normally aspirated cars(with optional 1 bar map sensor)
  • *Antilag Control
  • Soft-Cut Rev Limits
  • Boost Limit
  • Electronic Boost Control
  • 2-step launch control (Switched Input)
  • Definable Knock Control (two setting amplification with definable threshold) with adjustable fuel compensation.
  • Backup Spark map strategy when excessive lean condition or detonation is detected
  • Limited Onboard Data logging (Unlimited data logging through PC)
  • Password Protection for Intellectual Property
  • Many Programmable 2D outputs (Staged injection, intercooler spray, water spray, turbo timer, shift light, VTEC, fuel pump, etc...)
These units are not currently in production. Initial pricing may vary from $1600 to $2200 or more. These units will allow far more tunability then any other unit on the market and will allow you to push your car to higher power levels more safely. The more people that show interest the more likely that this is going to happen.
  • Plug and Play
  • EGR
  • Purge Control
  • Power Steering
  • Air Conditioning
  • Boost Control
  • Two Mappable Variable 3D Cam Maps 24 by 24 grid styled (VTC/AVCS/VVTi/Vanos)Closed Loop true cam timing by degrees Soon…
  • Injector Phasing
  • Tachometer Drive
  • *Antilag Control
  • Boost Limit
Will any shop be able to tune this EMS or does the shop have to have someone and the software to tune this?
I'm interested but want to make sure it's worth my time.
For example with Xede there is only one shop here in Ga that has the software to tune it. None of there other shops around here want to because not enough people have the Xede EMS
any system you buy comes with the software to tune it so there shouldn't be a problem with a shop tuning a car at all unless they are bs'ing you because they don't want to bother.
Any shop should be able to tune it, the software is very easy to use and is availiable for download off the hydra website.
The autotune feature on this unit also works VERY well for tuning the fuel maps. Plug in your wideband, plug in your laptop and it starts tuning, all you have to do is drive and remember to save the map when you are done.
Is this one of those standalones that you set up half way, go drive it around while it learns the tune, finish the installation, and then adjust the tune that it picks up on? Also, how well will that auto-tune function work on the direct injection? This car deffinately needs a standalone to climb up substantially in numbers, but I don't know that I could set up all the maps and correction maps and everything from scratch.
well basically being a PNP there will be some sort of map on there to get the car to run, then you can setup the auto-tune to tune it itself or you can tune it completely by yourself or your tuner shop. Aric runs it on his MSM.
What's the deal with CEL's/MIL's? Will this thing be able to fool dmv? Most states require plug into the ecu.
-C
