mrlilguy157
- 07 mazdaspeed 3
So I went fishing this morning, and I caught a bunch of stuff ;D
All parts are from an 07 ms3, which had 5000k miles on it. It was totalled from the rear, but the car was completely stock when it happened. No parts have been abused as far as I can tell. All prices DO NOT include shipping, unless otherwise noted. We can work together with zip codes to get accurate shipping costs. I ONLY BOUGHT THE DRIVELINE, I DO NOT HAVE THE WHOLE CAR.
All prices are OBO. The breakdown begins:
6speed 2.3l LSD Transmission: $750 SHIPPED. The transmission is in great condition, other than a hairline fracture or crack in the top of the housing. It almost looks like a deep scratch. No fluids leak from the transmission, and I would feel safe about mounting up the trans to a motor and into my car. I considered dropping my transmission and bolting this one up, and then going to the dealer to get it replaced under warranty, but I don't have the time or the money, or a local dealer to do that.
4 DISI 2.3l Injectors: $300 shipped Perfect condition, I think these are over $200 each from the dealer. Buy these and mail them to someone to get higherflowing injectors made, or add this to your extra motor.
OE Exhaust Manifold x2: $150 shipped. Its the exhaust manifold, its OEM, in fine condition. I have the copper gasket to go with it (used).
OE Downpipe x2 (without midpipe): $100. Perfect threads and perfect condition. Just the downpipe, nothing else. No 02 sensors, those are forsale below.
OE Motor Accessory prices:
Water pump: $65 shipped
Oil Pump/cooler: $65 shipped
Starter: $60 shipped
Perfect option for failed accessories or custom projects, like polishing that engine bay! Everything works just fine.
OE Turbo Inlet Pipe x2: $60 shipped.
OE MS3/MS6 Engine cover x2: $50 shipped Looks brand new.
OE Fuel Rail: $80 shipped. Includes rail, rail pressure sensor, and hardline which goes all the way up to the CDFP.
OE Turbo Oil Lines (return and feed): $60 shipped. Great, perfect condition.
Misc Wiring harnesses: $50 each. I have the daughter harnesses, but not the main harness which leads to the ECU.
Misc Parts, brackets, bolts, vacuum, coolant and oil lines, as well as the serpentine belt $15 shipped each, or $50 for everything.
Mods please let me know if the listing is OKAY, or if I need to revise, add or change anything. Thank you!
All prices are negotiable, as they all state, OR BEST OFFER. The more you buy, the better deals you get. Don't be afraid to contact me directly, or through PM. I can get better pictures of almost everything, as it will all be with me in Stillwater, Oklahoma 74077, and ship from there as well. The only items that will remain in dallas are the block and the transmission. If I get a buyer on those items, then I will drive home that weekend and build a box and frieght the items to you from dallas, zip code 75007.
Calling me is best, then texting, email, and PM. Get to me anytime, and I'll most likely pickup, other than between 12pm and 5pm central time.
Jonathan Martin
214.957.0461
jonathan.martin@mrlilguycdfps.com
Pictures:
Jonathan Martin
214.957.0461
Pictures:
