builthatch
i've done this on all my high compression hondas and it worked like a charm to reduce crank case pressures and eliminate any chance of oil ingestion.
That's where the oil is coming from causing the smoke issues.
There may be some bad turbo seals out there, but what most people describe sounds more like blow-by. It'll smoke some times, but not other times. If you get on it for a bit it goes away for a while. There is an oil catch resevoir bolted to the block. That is what the pvc valve is comming off of. If it gets full, the only other place for the oil to go is up the hose to the intake manifold, and subsequently into the engine. When you get on it, logic would suggest some of the oil in the resevoir returns to the block in the path it came in at.
Yes, but the procedure would involve a dealer tech removing the intake manifold. I don't trust them that much. You'd either have to use some sort of suction tool, or remove the case and let it spill everywhere. I'd rather have the sendary catch can located down near the fender so I can drain it easily when I change my oil.
Thats very odd, if Mazda put a catch can on there, then there has to be a way to empty it easily... I figured they would have imagined it getting full at some point...
Where is it exactly? I'm going home and checking it out!!
Why would mazda care? You already bought the car. The techs are probably supposed to empty it, but they're probably too lazy.
You have to remove the intake manifold to get to it. It's where the pvc valve is attached.
There's no oil catch can, there's only a pcv valve that works like on any other car that goes from the crank case to the intake manifold. The tube that goes from the valve cover to the intake that has the blue clips is for clean air to go into the crank case to balance out the low pressure (aka breather tube), when the fumes in the crank case is being sucked into the intake manifold it creates the low pressure. if you are to install a oil catch can, you'll be tapping into the pcv-to-intake manifold tube, not the valve cover to air intake tube.
