In Memory of Member 1338
Page 1 of 10 123 ... LastLast
Results 1 to 15 of 143
Thread: HOW TO: Install Boost Gauge into Drivers Vent
  1. #1
    07 Mazdaspeed3 TR
    Join Date
    Sep 2007
    Location
    SEPA
    Posts
    239
    Hey-- here are the steps I took to install my boost gauge into my drivers side vent with photos.
    Car:2007 Mazdaspeed3
    Gauge: Defi Link Meter BF Amber Boost in PSI, Defi Control Unit II
    Tools Needed:
    wire stripper
    wire cutters
    wire crimpers
    pliers
    zip ties
    wire snake or wire hanger
    flat head screwdriver
    philips head screwdriver
    Dremel tool w/sanding bit (for 60mm gauges)
    automotive fuse taps
    female terminals
    ring terminals
    patience and time
    Note: I developed this guide using my own knowledge as well as information researched from resources such as specialized online forums. The information on this page is meant to be a GUIDE and in no way should be considered official installation instructions. Use this guide at your own risk. If at any time you are not sure that you are doing something properly, please seek the advice or services of a professional.
    1. Pop the hood and locate the vacuum tube running from the manifold to the bypass valve.
    2. Cut the tube using wire cutters and insert T connector into each end and into one end of the supplied vacuum tubing that came with your gauge.
    3. Zip tie all 3 connections tightly
    4. Re-install vacuum tube onto bypass valve and secure with clamp using pliers.
    5. Route the other end of the supplied vacuum tubing to where you are going to be mounting your boost pressure sender. As you can see I mounted mine with a nut and a screw to a hole I drilled in my battery box.
    6. Under your drivers side dashboard, follow the trunk release cable and locate the point at which it passes though the firewall. There will be a rubber grommet around the cable. Pull the rubber grommet out of hole and feed a wire hanger or wire snake through the hole in the firewall. It will come out inside the engine bay near the drivers strut tower.
    7. On the engine bay side, tape your boost sender wire to the other end of the wire hanger and slowly pull the hanger back through the firewall, being careful not to snag the wires. Once though the firewall, you can carefully feed the entire length of wiring from the engine bay into the cabin. Re-mount the grommet back into the firewall, adjusting it around the boost sender wires as well as you can.
    8. Pull up the drivers side scuff plate (the piece that says mazdaspeed) and put it somewhere safe. The scuff plate is held in by tension clips, so be very careful when removing-- apply even steady pressure as you pull--too much stress on one clip could crack or break it.
    9. Remove the drivers door kick panel (more tension clips and one 'pop' clip).
    10.Using a flathead screwdriver release the hood release lever by sliding it in through the top, and releasing the tab. The lever should pop off into your hand and allow you to access the phillips head screw behind it.
    11. Remove the phillips head screw, and then the lower drivers side dash. The dash is held in with tension clips.
    12. Once the dash is free, remove the plug connectors for the DSC, Dimmer, HID Level (if equipped) and OBDII port to remove the lower dash completely.
    13. Now comes the really tricky part- removing the vent. This step was very hard and painstaking as I wanted to be sure not to damage any of the vent parts. To remove the inner vent, I got a good grip on the louvers with both hands, applied steady even pressure, and it popped right out. (passenger side vent shown for photo demonstration)
    14. Removing the inner vent was even harder. With the lower dash removed, you can access the inner vent cup on each side. I used a very large flathead screwdriver to push the tabs in that release the cup from the opening. Pictured below is the underside of the cup (marked with white writing) that you want out. This is not the best pic and I know it doesn't show you much. The tabs your need to put pressure on will be obvious when you get to this point.
    15. I worked the outer vent cup on each side with a screwdriver until I was able to pop it out of the vent opening. This was the hardest part of the whole install process, because it took a LOT of pressure to pop it out, to the point where it felt like you were breaking it. Just go slow and be careful. Once you get the two vents out, the opening will look like this:
    Here is what the vent cups looks like when out of the car- outer vent on the left, inner vent on the right:
    16. Using the wire cutters, carefully snip the louvers out of the inner vent cup. After the louvers are removed, cut away the honeycomb patterned grating behind the where the louvers were.
    17. Using a Dremel tool with a sanding bit, carefully begin to sand the inside of the inner vent. For my 60mm gauge I needed to take out as much material as possible to make it fit. If you are using a 52mm gauge, at this point you will need to figure out how to mount and hold the gauge inside the inner vent cup. Be careful at this step, one mistake could send you to a dealer for a new $50 vent assembly.
    18. I blocked off the vent by cutting an old tupperware lid to size and taping it inside the vent tube with electrical tape. I don't know for sure if it is necessary to block of the vent, but I did it just for peace of mind.
    19. To wire my gauge and control unit, I decided to use the fuse panel found behind the glove box.
    20. To access this fuse location, first remove the strip of plastic trim that surrounds the Radio LCD display. Again, these are tension clips so be careful!
    Pop the clips from left to right or you will snap off the tab that holds the trim in on the far right side.
    21. Take out the two black phillips head screws that hold the glove box in.
    22. Just like the lower drivers side dash, the glove box is held in by a series of tension clips. Apply even pressure and pull the glove box out slowly and carefully. There will be a wire that connects the glove box lamp, you can
    disconnect this if you like, but it isn't really necessary. This picture shows the wiring that I ran from my gauge to the glove box in order to wire up my Defi Control Unit-- they wont be there if you are removing your glove box for the first time.
    23. Run your wiring--For a stand alone style gauge, you will need to run your boost sensor harness (from under the drivers dash) into the drivers side vent opening. Then you will need to run the power harness behind the center console and into the fuse compartment behind the glove box. Defi Link Gauges are a little more complicated. For my gauge there is a harness that comes from the sending unit (under the hood) and goes to my control unit that I am mounting in my glove box. Then another harness runs from the control unit to the back of the gauge. Finally there is a 3rd 4 wire power harness that comes from the control unit that I need to wire into the system: Black (ground), Red (constant 12v) Orange (switched 12v) and White (Illumination). These wires may vary depending on the brand of gauge you have, however any gauge will need at least a switched power, illumination power, and ground. To tap for power, I used Radio Shack automotive fuse taps (about $2/4) and blade style female terminals (about $2/10).
    The fuse taps 'piggyback' onto an automotive fuse and allow you to run a blade terminal off of the same circuit. This is a great option for people like me that don't want to bother with cutting, splicing or soldiering wires. If you ever need to remove the gauge or rewire it, you just disconnect the connectors and remove the taps-its very clean and easy.
    24. Because my gauge is tinted- it needs to be constantly illuminated while the car is on or you cant see it, so I stripped both ends of the switched and illuminated power and crimped both on a single female terminal. I then stripped and crimped another female terminal onto the constant power wire.
    25. Using a fuse tap, I tapped the F43 fuse (cigar lighter) for the illumination and switched power. This will turn the gauge on and light it up when a key is in the ignition or the engine is turned on. I tapped the constant power wire to the F75 fuse (drivers door locks) This allows the gauge control unit to have constant 12v-- required if you have a gauge that needs to save settings or remember warning/peak levels. If a constant 12v is connected to a switched
    source, it will lose all settings when the engine is turned off. NOTE: The radio fuse is NOT a constant 12v source from this location (I learned this the hard way and had to rewire it to the door locks). Every fuse in this location is numbered and easily located in this Connector Pinout document. If you have a traditional gauge that needs switched and illum wired separately, you can use the F43 cigar lighter fuse (switched power) and the F82 dash illumination fuse separately.
    26. I stripped and crimped the ground wire to a ring terminal and attached it to a ground bolt right above the glove box on the dash frame (my terminal is the blue one):
    27. Connect the gauge to the harness plugs (do not install it into the vent yet) and turn the car on to test for proper gauge illumination and function.
    28. Secure all wiring away from moving parts and heat sources with zip ties.
    29. Feed the boost source harness (from engine) and power harness (from fuse terminal) up behind the drivers vent and through the vent opening. Carefully reinstall the glove box, lower drivers dash, drivers kick panel and scuff plate.
    30. Install your gauge into the inner vent cup, snap the inner vent cup into the outer vent cup and plug in the wire harnesses that are feeding out of the drivers vent opening.
    31. Finally, snap the whole gauge/vent assembly into the upper dash vent hole and hope that you didn't make a mistake. I,for one, never want to have to take the vent out again...
    32. Enjoy your new super-clean boost gauge vent install!
  2. #2
    07 Mazdaspeed3 TR
    Join Date
    Sep 2007
    Location
    SEPA
    Posts
    239
    feel free to hit me up with any questions you might have
  3. #3
    Registered Member Minischumi's Avatar
    Mazdaspeed 3
    Join Date
    Aug 2007
    Location
    Switzerland
    Posts
    35
  4. #4
    Banned
    mps 3
    Join Date
    Nov 2007
    Location
    texas
    Posts
    928
    nice write up looks sleeek, i still like mine on the steering collum though it doesn't block anything and it's perfect to see your boost while your moving through the gears
  5. #5
    Registered Member BlackMS6's Avatar
    Join Date
    Jan 2008
    Location
    new york, ny
    Posts
    256
    good write up... and nice gauge choice...DEFI FTW!!!
    TOO MUCH TO LIST!!!!
  6. #6
    Registered Member
    Mazdaspeed 3
    Join Date
    Jun 2007
    Location
    Chicago
    Posts
    197
    one of the best write ups I've ever seen. Thanks much!
  7. #7
    Mr. Registered User 2ManyCars's Avatar
    2008 MS3 GT (SOLD)
    Join Date
    Nov 2007
    Location
    Poway, CA
    Posts
    309
    Good writeup. One tip I gleaned from someone on another thread was using the mini "Add-a-Fuse" connectors. This allows you to tap into the fusebox in a similar way but to put a fuse on the line as well.
    2008 MS3 GT (Just SOLD)
  8. #8
    07 Mazdaspeed3 TR
    Join Date
    Sep 2007
    Location
    SEPA
    Posts
    239
    Quote Originally Posted by 2ManyCars View Post
    yeah I almost got those but after realizing that they cost $5 each I found these at radio shack for much much less. The Defi constant 12v has its own inline fuse anyway. In my opinion its a little overkill to fuse the illumination an switched power. I couldn't bring myself to pay $5 a pop for 2 cents worth of wire and fuse...
  9. #9
    Registered Member flipmode815's Avatar
    mazda, mp3, #908
    Join Date
    Jul 2005
    Location
    Goshen, Indiana
    Posts
    840
    damn those gauges are sweet!!! how did you manage to find the red defi gauges?
    2001 lazer blue MP3 #908
    (bluemp3)
  10. #10
    Registered Member mazdaspeedjay's Avatar
    Join Date
    Nov 2007
    Posts
    153
    thanks been looking on doing this i put my boost gauge next to my cig light but i wanted to put my wide band a/f gauge in the driver vent. thanks
    My cars:
    -08' Mazdaspeed3 mica black, COBB Short air intake , STRi Electric boost gauge mounted under radio. STRi Turbo timer, AEM UEGO Wide band A/F ratio gauge, Turbo X's Hybrid 1/2 1/2 Blow off valve. turbo x's test pipe with adapaters. TRZ Dog bone mount with race bushing. Stock DP and exhaust. spiking 20 PSI holding 16 PSI of boost on home made boost controller, COBB Access port ( already placed my order just waiting like everyone else for it )
  11. #11
    Registered Member Boosted333's Avatar
    '08 MS3
    Join Date
    Dec 2007
    Location
    Wallingford, CT
    Posts
    146
    Thanks, nice job and perfect match on the gauge! I like the 60mm choice as well.
  12. #12
    2008 MS3 GT (SOLD)
    Join Date
    Nov 2007
    Location
    Poway, CA
    Posts
    309
    Hey one more question. Would it work for your install to access the fuse box from under the dash? When I did mine, I did not pull any of the dash off on that side to get to it. It just pops down from the panel under the passenger side dash per the owner's manual. Would that help simplify the steps a bit?
  13. #13
    07 Mazdaspeed3 TR
    Join Date
    Sep 2007
    Location
    SEPA
    Posts
    239
    I don't know, maybe thats another fuse box? The one used definitely would not be able to be reached with the glove box in the car. There are literally hundreds of places you can tap gauges on wire harnesses on the car if you know the right colors and don't mind soldiering.
  14. #14
    07 Mazdaspeed3 TR
    Join Date
    Sep 2007
    Location
    SEPA
    Posts
    239
    Quote Originally Posted by flipmode815 View Post
    They are Defi Link BF Series Amber Gauges (they also come in white)
    PM me if you are interested, I can get them at a discount.
  15. #15
    nice job, how is your window fog? still good?
Similar Threads
  1. how do u install boost gauge?
    By clos561 in forum Mazdaspeed3
    Last Post: 03-19-2008, 09:23 AM
  2. Boost gauge install question
    By SpeedBeaver in forum Mazdaspeed Protege
    Last Post: 06-02-2005, 11:09 PM
  3. Boost gauge install
    By lancebav in forum Mazdaspeed Protege
    Last Post: 04-16-2005, 02:13 AM
  4. MSP owner, install of a boost gauge?
    By Stou in forum Mazdaspeed Protege
    Last Post: 12-26-2002, 03:05 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
