VersaTuner - tuning software for Mazdas
Page 1 of 3 123 LastLast
Results 1 to 15 of 37
Thread: The infamous P0421 code, need some help!
  1. #1
    Registered Member
    Join Date
    Jan 2008
    Posts
    7
    Hey all,
    I have been doing alot of searching on this topic and im not sure how to proceed. Here is the deal.
    About six months back I had ignition problems that were hit and miss on my 2002 model, all stock. And the CEL code then was cylinder misfire. Over time I eventually changed the plugs and ignition coils and it fixed the problem.
    But my check engine light is still on reading the P0421 code now "Cat below threshold during warmup".
    Question is: Is the cat damaged from the misfire?
    Should I change the O2 sensors?
    I inspected all the harnesses on the O2 sensors for loosness, rechecked the plugs for fouling and also there is no exhaust leaks detected. I have reset the CEL a few times by dissconnecting the battery for a few min. 40miles later its on again with same code.
    Im stumped and I dont want to take it to Mazda to rape my wallet. Car runs perfect and gets 30mpg... But im at 77k and the emissions warranty is through 80k i believe. Any ideas are greatly appreciated...
  2. #2
    The Pitbull Fan dwpeek's Avatar
    02 P5
    Join Date
    Jun 2005
    Location
    Mo.
    Posts
    287
    Check some of the other threads having to do with code. O2 sensor of EGR valve. There are alot of thread on this matter. Or to simpify, check the FAQ
    I GOT A MOTOR!!!
  3. #3
    Registered Member
    Join Date
    Jan 2008
    Posts
    7
    Yea i have searched until my eyes are red..
    What is the deal with this non-fouler method i see? Does it keep the CEL from coming on at all? And where can i get the parts for this install and instructions?
    Or perhaps should i just buy a new O2 sensor? Car runs great...
    Help....
  4. #4
    手前の言葉が俺は聞き捨てよう TheMAN's Avatar
    Join Date
    Oct 2002
    Location
    Dallas, TX
    Posts
    5,839
    dude, it's exactly what the code says... the cat is bad, the car is under warranty, stop wasting time and bring it in and get it replaced FREE!
    yes, misfires can kill cats
    TheMAN
    '01 BJFP MT
    '05 BK3P HB AT
    '16 BMYFS AT
    For Protege and Mazda3 info, come see the Protege FAQ
  5. #5
    02 P5
    Join Date
    Jun 2005
    Location
    Mo.
    Posts
    287
    Quote Originally Posted by TheMAN View Post
    That's why he's THE MAN.
  6. #6
    Registered Member
    Join Date
    Jan 2008
    Posts
    7
    Yep, appt made at local garage that has the diagnostic machine to see what is defective. More to follow...
  7. #7
    Join Date
    Oct 2002
    Location
    Dallas, TX
    Posts
    5,839
    the "diagnostic machine" doesn't tell you shit about what's defective, it only tells you what you already know... there is NO magic to automotive repair... you can't hook up a computer to the car and expect it to magically fix all problems nor can you expect it to pinpoint exactly what is wrong with it
    I told you, your cat is bad... stop wasting time and money and go get the cat replaced under warranty! your misfires is what killed the cat, and furthermore, the diagnostic systems for detecting a bad cat is 99% accurate compared to other systems in your car... there is NO need to waste time and doubt what the ECU is telling you because of this
    replacing O2 sensors and other parts = waste of money because they're still doing their job and the ECU is telling you what's wrong with the car!
    bringing it to joe's auto repair = waste of money because they're going to charge you to look at the car only to find what I've already told you... the cat is bad!!!
    bringing it to the mazda dealer = SAVE MONEY because this specific problem is covered under warranty! there is NO "rape my wallet"
    wasting time with all these superficial diagnostic and repair attempts = waste of time and money because the next thing you know, your car has more than 80000 miles and you're no longer under warranty
  8. #8
    Registered Member brett02's Avatar
    Join Date
    Dec 2007
    Location
    Kansas City
    Posts
    110
    I have to agree with "theman" I researched the same thing that you are having problems with and if my car didn't have 86k on it I would have gladly let Mazda put a new cat on it. Yours is under warranty, take it to Mazda and have them replace it.
  9. #9
    Registered Member
    Join Date
    Jan 2008
    Posts
    7
    Problem is everybody wants to put the machine on it to see what is wrong. Yes this was done at autzone but nobody will touch the car until they put their computer on it. Its aggravating but nonetheless I have an appt with a shop next week and I will argue the case that I have the code so order a new cat for me. We will see how it goes. I hate dealing with auto repair places myself they just piss me off...
    I will bring this with me:
    If you have valid warranty claim, you cannot be charged for any costs associated with the diagnosis or repair of the problem, including labor charges, parts, or miscellaneous items that are necessary to complete the repair. For example, if a manufacturer agrees to replace a catalytic converter under the emissions warranty, you should not be charged for the diagnosis of the bad converter, or any pipes, brackets, adjustments, or labor needed to complete the replacement.
  10. #10
    Registered Member memo79's Avatar
    Donated: $10
    2002 Black Mica P5
    Join Date
    May 2004
    Location
    Fort Riley, KS
    Posts
    861
    Did you read the last post TheMan put up?
    I'm not trying to be an ass here, but I'd do the following:
    Listen to what TheMan says.
    I'll simplify:
    1. Cancel your appointment with whoever it is you have it with.
    2. Take it to Mazda dealership.
    3. Enjoy your new cat.
    Of course Mazda is going to put their Diagnostic machine on it. They want to know what the problem is. DON'T tell them you know it's P0421 or whatever. Just let them do their job. They will see what it is and fix it.
    Quote Originally Posted by bigyzf
    The real reason your getting pissed off is 'cause you keep going to the wrong places. Go to Mazda.
    (p5black)
  11. #11
    02 P5
    Join Date
    Jun 2005
    Location
    Mo.
    Posts
    287
    Quote Originally Posted by dwpeek View Post
    I think it was me who said, "that's why he's THE MAN".
  12. #12
    Join Date
    Dec 2007
    Location
    Kansas City
    Posts
    110
    Take it to the Mazda dealership, they will read what the code is under warranty and fix. I know I am a newbe here, but I just got done dealing with all of this my self.
  13. #13
    Registered Member
    Join Date
    Jan 2008
    Posts
    7
    Appt made with Mazda this week. More to follow..
    Confirmed, cat ordered, will be replaced free!!!
  14. #14
    Registered Member
    Join Date
    Jul 2006
    Posts
    66
    The Man,
    I would greatly appreciate some of your knowledge and guidance on this CAT issue. I currently drive a 2001 Protege ES with 95000 miles on it. I have thrown this same code P0421 twice already in two months. It was on for about 3 days, went off... and a month later, yesterday, it just came on again. Based on what you have said, I definitely have a bad CAT? Driving still seems perfectly normal, nothing unusual with the light on. I do notice occasionally when at a red light, the idle drops down a little close to 0 and then jumps back up to normal, a little below the 1.
    Now I'm guessing because I already have 95000 miles on the car, it is no longer under warranty right? If i wanted to replace the CAT myself, is it a DIY job or definitely an experienced mechanic job? I believe their is two CAT's on my car. Which one would be giving me this P0421 code? Thanks in advance.
  15. #15
    Registered Member NCZ13's Avatar
    Join Date
    Jan 2007
    Location
    San Marcos, CA
    Posts
    3,911
    its your precat that is bad.
    when a cylinder misfires, not all the fuel is ignited, causing the fuel to travel down the exhaust system through the cats. this is what damages the cats. the unburnt fuel.
    whats giving you the code is your precat. being that the secondary cat has no o2 sensors after it. you can either A) stick a nonfouler on the bottom o2 sensor and kill walruses in alaska with your poisonous gases, or b) you can get a new stock manifold. but if your going to do that you might as well get a race header that eliminates the cat altogether, and gives a the car a nice boost in power in the mid to top end.
    2008 Mazdaspeed3
    1986 mazda rx7
    2002.5 mazda protege5 (sold 12/26)
    FS RULES:
    http://www.mazdas247.com/forum/showthread.php?t=98864
Similar Threads
  1. p0421 code among others
    By brett02 in forum Protege5
    Last Post: 01-05-2008, 12:14 AM
  2. Code P0421
    By LX_StreetGlow in forum Mazda Protege
    Last Post: 10-19-2007, 01:25 AM
  3. Cel Code P0421
    By BlkMica_03 in forum Protege5
    Last Post: 04-19-2007, 05:48 PM
  4. Thrown Code P0421
    By wiley858 in forum Protege5
    Last Post: 04-03-2007, 05:27 PM
  5. Engine Code P0421 - O2 Sensor Question
    By jgrant59 in forum Mazda Protege
    Last Post: 12-15-2005, 10:31 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
