Vindikacione
So, am I the only one with a throttle fluctuation problem?
Car throttle sensor was probably getting a bad input. My guess is the ECU spiked (something electrical got jacked up), when I had to jump start the car (again, for the third time- bitched about this in another thread, under electronics, but the problem didn't arise the first two times I jumped the car). But I'm not certain what caused the problem.
Conditions: Weather 34-36 degrees F. Snow on the ground. COBB SRI. Forge BPV (It was replaced with stock BPV, to see if it was the cause, but it wasn't).
Symptoms: The RPMs would jump from 800 to 1400 RPMs for no apparent reason at idle. While shifting the RPMs would remain constant, with no pressure on throttle, causing the engine to surge as the clutch is pressed. Usually the RPMs drop as soon as you release the gas and hit the clutch, but with this problem the throttle "thought" it was getting pressed, when it wasn't. VERY weird. Simply turning the car off and on, didn't make the problem go away.
Fix: Used Push-the-DSC-Button-Mod-before/during-start.
Problem went away with pushing the DSC button (Read in the good manual how DSC adjusts torque to road conditions. I assumed this might be controlled through the throttle.)
Haven't driven the car since.
