- 2003 Mazda Protege 5
Well I need help with something. I'll try to lay it out as simple as possible.
Problem:
No power to amplifier. I just bought new wiring for the battery to inline fuse (8 inches from battery), fuse holder (ANL Style), and ANL fuse. Did I buy the right fuse? The fuse is 60 amp, and the amplifier has three 25 amp fuses on it (75 amp total), all of which are ok. I read several sites that said get just under how many amps the fuses are on the amplifier.
Now I used to have an AGU fuse but I cracked the case for it and decided to buy all new stuff. I did some research and bought these items:
-MTX 60 amp ANL Fuse (https://www.ebay.com (commissions earned))
-Stinger 4 Gauge Power Wire (https://www.ebay.com (commissions earned))
-Stinger Ring Terminal (https://www.ebay.com (commissions earned))
-Rockford Fosgate ANL Fuse Holder (https://www.ebay.com (commissions earned))
No amplifier and subwoofer worked fine before I did this and I've never had any problems, so I doubt it's the amplifier itself. I believe the amplifier remote wire is still connected from where I checked it, all attachments are correct to the amplifier, and the amp is grounded. Any suggestions?
Problem:
