CorkSport.com is MAZDA PERFORMANCE!
Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: Power steering belt install
  1. #16
    Registered Member
    Mazda, Protege5
    Join Date
    Dec 2016
    Location
    Brooklyn
    Posts
    18
    Thanks you thread from 2007 saved me $$$ as well
  2. #17
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    3,905
    Here's the info to adjust the tension on your belts but it's a pain to try and reach in there to measure 10 or 11 mm while trying to guesstimate 22 lbs. of pressure.
    A good trick is to reach in and twist the belt between the pulleys. You should be able to twist it at least sideways and no more than upsidedown.
    Too tight will wreck your alternator bearing and too loose it will squeal constantly.
  3. #18
    Registered Member
    02 Protege LX, 03 Proteg5, 09 Miata, 07 Mazda3, 13 Fit, 09 Ody
    Join Date
    Aug 2013
    Location
    MD
    Posts
    66
    Broke on my daughter's car today (the 02). Changed this evening, no prob.
    13 Fit | 09 Ody | 09 Miata | 07 Mazda 3 | 03 Protege5 | 02 Protege
Similar Threads
  1. Mazda3 Base Model - Adding Power Windows and Locks
    By cbutters in forum Mazda3 Infotainment
    Last Post: 04-13-2012, 09:09 PM
  2. Power Steering - more assistance?
    By Silo in forum Mazda6 Lounge
    Last Post: 08-27-2007, 05:36 AM
  3. HELP: HOW To change Power Steering Fluid?
    By skilletrx in forum Off Topic
    Last Post: 07-05-2007, 09:26 AM
  4. "center" for power steering?
    By pasadena_commut in forum Mazda Protege
    Last Post: 10-10-2006, 06:43 PM
  5. Help with 96 Protege power steering
    By jamesdak in forum Mazda Protege
    Last Post: 03-31-2006, 09:25 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
