The ECU is pretty smart--it may adapt even without a reset. If you're concerned you're not getting all the power you think you should, resetting the ecu won't do any harm other than running hella rich and killing your mileage for a couple hundred miles. Disconnect the negative terminal, press the brake pedal for 30 seconds, and reconnect the terminal--your ECU is reset.
