Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 61 to 75 of 131
Thread: Solution To Flickering Fan Speed 2 or 3 A/C
  1. #61
    Registered Member Weborific's Avatar
    Join Date
    Feb 2006
    Posts
    334
    Quote Originally Posted by pasadena_commut View Post
    Well, to give them the benefit of the doubt, I suspect that not all flickering AC light problems are the same. For instance, on my P5 with the fan on 3 the AC usually won't work (the light goes out) if the car has been parked in the sun for a couple of hours on a very hot day. Run it on position 4 for half an hour and 3 will work again. If it hasn't been parked in the sun all 4 positions work and there is no flickering. Hard to see how that could be a contact issue.
    The P5s AC is just as mediocre as the AC was on my old 323. In both cases the AC blows nice and cold when it's not very hot, but when it's 95 or more it can't keep the car's interior as cool as desired. The air blows out cold, just not, apparently, with enough volume to remove all the heat soaking into the car. Subjectively it feels just like running too small a window AC unit in too big a room - cold air, but the room heats up anyway.
    It very well CAN be a contact issue in this case as well. Heat causes the metal to expand. So the female connector that hugs the male connector will open a couple of thousands of an inch and break contact. Squeeze your contacts with pliers and leave your P5 in the sun all day. Let me know how it goes. The electronics in the car shouldn't go woncky at a low temperature like 40 degrees celcius. 70-80 degrees, maybe.
  2. #62
    Join Date
    Feb 2006
    Posts
    334
    Well....after 4 weeks of flawless functionality...the flicker came back!! it works properly most of the time but have had the A/C light go out 3 times now. My final solution...I'm gonna solder the damn wires directly to the switch!!
  3. #63
    Fire Fighter/USAF DeadGeneration's Avatar
    Donated: $20
    '04 RX8
    Join Date
    Apr 2005
    Location
    Laughlin AFB, Texas/Mexico
    Posts
    1,834
    UPDATES! I will wait to make sure this solution is headed in the correct direction.
    2003 Midnight Blue Protege5 Gone
    2004 Nordic Green RX-8 Gone
    2012 Dark Gray Metallic WRX Current
  4. #64
    Registered Member buttthrax's Avatar
    2K2 P5
    Join Date
    Dec 2004
    Posts
    119
    I noticed my car does this as well. If its just the light then I won't even bother with it.
  5. #65
    Registered Member terbow's Avatar
    Donated: $5
    03.5 MSP
    Join Date
    May 2004
    Location
    Pawt, Rhode Island
    Posts
    4,798
    its not the light , well in most cases, youll notice the air gets warmer.
  6. #66
    2K2 P5
    Join Date
    Dec 2004
    Posts
    119
    Quote Originally Posted by terbow View Post
    Yeah I think it is more than just the light. I noticed this problem ~2 weeks ago while driving on the interstate and noticed because of the changing torque because of the AC cutting in and out.
    I still probably won't do anything about it though.
  7. #67
    Resident Asshole Maxx Mazda's Avatar
    Donated: $10
    Completely Stock P5
    Join Date
    Aug 2003
    Location
    Calgary, AB
    Posts
    7,333
    I just did the fix. COmpletely remedied my problem! Add another to the "it works" list!
    Has anyone that's done this actually had it fail?
    Completely stock... (lol)
  8. #68
    Registered Member LinuxRacr's Avatar
    Donated: $15
    2001 Mazda MP3
    Join Date
    Sep 2001
    Location
    Dallas/Fort Worth, Texas
    Posts
    12,390
    Moving this to the How-To- Section
    Performance Mods:[Steedspeed v2. Turbo Manifold] [Precision PTE CEA 5130 Turbo] [Pope 3-inch Downpipe] [Molnar Forged Rods] [Wiseco Forged Pistons (9.1:1)] [NSN Motorsports Thermal Intake Manifold Spacer] [Haltech E6X Stand Alone] [Haltech Boost Controller] [2007 WRX 565cc Dark Blue Injectors] [AEM UEGO 30-4100 Wideband O2 Sensor] [Vibrant 3-inch TurboBack Exhaust with Custom 3-inch mid Pipe] [ ACT Z66-XTSS Clutch] [Fidanza Flywheel] [Synapse Synchronic BOV] [AWR Motor Mounts] [PWR High Performance Radiator PWR1306] [Mazdaspeed Oil Cooler ] [Tein SS Coilover Suspension ] Other Mods: [Intel Atom-based Touchscreen Car PC] [Defi D-Series Boost Gauge] [Nordskog Digital Fuel and Oil Pressure Gauges] [Dave B. Brushed Aluminum Gauge Rings]
    The things we own will eventually end up owning us one way or another....
  9. #69
    Donated: $5
    03.5 MSP
    Join Date
    May 2004
    Location
    Pawt, Rhode Island
    Posts
    4,798
    itll work as long as the trace on the pcb isnt burned out. which is why it could still fail, but if u catch it early i think this will prevent it from happening
  10. #70
    Donated: $15
    2001 Mazda MP3
    Join Date
    Sep 2001
    Location
    Posts
    12,390
    Got pictures to this trace on the PCB board?
  11. #71
    Donated: $5
    03.5 MSP
    Join Date
    May 2004
    Location
    Pawt, Rhode Island
    Posts
    4,798
    saw it on here once. mine wasnt busted or id go snap a pic.
  12. #72
    Donated: $10
    Completely Stock P5
    Join Date
    Aug 2003
    Location
    Calgary, AB
    Posts
    7,333
    Quote Originally Posted by LinuxRacr View Post
    Antoine already did!
  13. #73
    Donated: $15
    2001 Mazda MP3
    Join Date
    Sep 2001
    Location
    Posts
    12,390
    Quote Originally Posted by Maxx Mazda View Post
    No, I moved it this morning. I moved it because I saw it in the Protege 5 section.
  14. #74
    Join Date
    Feb 2006
    Posts
    334
    OOOOH...so THIS is where my post went... hehehe. Thanks!
  15. #75
    Registered Member pasadena_commut's Avatar
    Protege5 2003
    Join Date
    Oct 2005
    Location
    Arcadia, CA
    Posts
    1,204
    Quote Originally Posted by Weborific View Post
    I cleaned and tightened those contacts a week ago and yesterday left the car out in the sun (104 degrees, ugh). As before, in position 3 the fan would blow but the AC light was out. AC light on in 1,2, and 4. After parking the car in the shade for 20 minutes the AC light worked again in position 3. So I don't think this is a contact problem, or if it is, it isn't at that contact.
    Since the AC light comes on at 2 and 4 I doubt this has anything to do with current levels or the compressor etc. Seems most likely to be a poorly temperature compensated electronic circuit.
Similar Threads
  1. Replies: 294
    Last Post: 06-04-2019, 06:51 PM
  2. POLL: Flickering A/C solution
    By Weborific in forum Protege5
    Last Post: 06-24-2012, 09:29 PM
  3. HID flickering??
    By xitoxic in forum Protege5
    Last Post: 03-01-2012, 12:19 AM
  4. Solution To Flickering Fan Speed 2 Or 3 A/c
    By Weborific in forum Mazda How-To
    Last Post: 07-27-2011, 04:05 PM
  5. Flickering AC, how much should I pay?
    Last Post: 07-28-2007, 11:52 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
