In Memory of Member 1338
Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Thread: BOV Vac Line and wastegate line configuration
  1. #1
    Eats All VeeTek RevLimitLaunch's Avatar
    06 MS6/03.5 MSP
    Join Date
    Jul 2006
    Location
    Candia/Manchester, NH
    Posts
    709
    well to start off the msp is boosting at 15-20psi depending on how fast i catch it and let off...not good...only mods are k&n filter kit and turbo back 2.5" no cats nor esonators and of course a boost gauge. it was hooked up to the small u shaped vac line and then i hooked it up to the intake mani vac line to the bov just to verify the pressure i got. same thing. i set up a boost controller and no matter how much in or out i set it, same thing. brought it to mazda and they said they won't touch it because the exhaust has raised the pressure haha...NO! it definiltey didn't. they also said my wastegate and bov vac line to the intake manifold is 'hacked up and not in the right places' even though i never touched it until after the boost issue im having. so can someone please post up some pictures of where the wastegate line goes to please just to verify my line is right.
    any other ideas to why this crap is happening?
  2. #2
    * Driver/Rider For Hire * Knox Joe's Avatar
    Donated: $50
    Ti MSP
    Join Date
    Jun 2006
    Location
    Knoxville, TN
    Posts
    2,446
    You need to re-route the hoses.
    You don't want anything between the boost controller and the wastegate.
    You basically just have to just re-route the BOV/BPV somewhere else.
    On any given weekend, there are more Mazdas on the road-race tracks of America than any other brand of vehicle.
  3. #3
    06 MS6/03.5 MSP
    Join Date
    Jul 2006
    Location
    Posts
    709
    well as of now i have line from intake mani going to the bov, about 6 inches from bov it "T"s and goes to the wastegate. nothing else is in those lines currently, except the boost gauge actually which is a few inches from the IM currrently.
    any way of a photo to show, i hate having to go by words, im a see it do it guy. lol.
  4. #4
    No longer an owner.. ItsSlow's Avatar
    99 gsr, 93 civic, 87 200sx
    Join Date
    Nov 2006
    Location
    Memphis, TN
    Posts
    1,288
    Here ya go..
    You can see the blue hose and where it "t's" off and goes to the wastegate..
  5. #5
    Registered Member MzD808SpD's Avatar
    Ti-Mazdaspeed protege
    Join Date
    Jan 2004
    Location
    Honolulu, Hawaii
    Posts
    104
    I wouldn't put more than 2 things on one vaccum source.
  6. #6
    Donated: $50
    Ti MSP
    Join Date
    Jun 2006
    Location
    Knoxville, TN
    Posts
    2,446
    Like I said re-route it, so that there is nothing in between the boost controller and wastegate. Get the BOV off of those lines. Run it to the brake booster, or somewhere. You cannot have the BOV and the boost controller on the same lines. No T fitting, nothing. Just run it straight from the mani to the boost controller, then to the wastegate, and you're done.
    you don't need pictures, just do it.
  7. #7
    06 MS6/03.5 MSP
    Join Date
    Jul 2006
    Location
    Posts
    709
    ok ok, thats easy, ill re-route and run the bov to the brake booster line. boost gauge will go there too. don't think much is gonna happen though. i removed the line of the wastegate and blew into it and i can keep on blowing into it over and over, i think the diaphragm is torn in that pos. isn't there a tsb for it? i tried searching quick didn't come up with info...ill prob try a lil later again when i get a chance unless someone posts it up for me here.
  8. #8
    I gots SPICE jmv's Avatar
    2003 MSP #1475
    Join Date
    Oct 2005
    Location
    San Antonio, TX
    Posts
    2,321
    Quote Originally Posted by RevLimitLaunch
    so long as you can rule out a cracked/torn vac line as the reason the air is going through, that means your WGA is bad. I don't think there was a TSB, but i could be wrong. You can always order the ATP replacement for $60 instead of going the expensive route through the dealer.
  9. #9
    MSP #1264 msp35's Avatar
    03.5 MSP
    Join Date
    Apr 2004
    Location
    Knoxville, TN
    Posts
    1,492
    I doubt it's due to a leak. Odds are it is the WGA.....get it changed before you join the zoomzoomboom club.
    #1264 Cardomain
    FS: Stock S-pipe & J-pipe.
    -Used for 20k miles. $200obo
    Stock MSP Racing Beat Springs
    -Used for 20k miles. $100obo
  10. #10
    06 MS6/03.5 MSP
    Join Date
    Jul 2006
    Location
    Posts
    709
    yeah i've just heard around here and there people speak of a tsb for the WG but it may not be there since i never saw anything posted on the msp problems threads that lists all tsbs/recalls etc. im going to hook up a vaccuum pump tonight to see if the diaphragm will hold any type of pressure, if not then that solves that problem and the atp will be on order. anyone got the part number for one around 8psi?? thanks i can't find any vendors that have it and i even googled it with no luck.
  11. #11
    AFCed Since 8/25/07 Alejo_NIN's Avatar
    RadonElement.Com
    Join Date
    Jun 2005
    Location
    Miami Lakes, FL
    Posts
    4,912
    the ATP sr20det WGA sold as 6PSI is actually a 8PSI for some reason....
    that's the one everyone gets.
  12. #12
    Donated: $50
    Ti MSP
    Join Date
    Jun 2006
    Location
    Knoxville, TN
    Posts
    2,446
    I dunno, I had this same exact problem. I installed a DSMBC and it would just keep spiking to 15 psi.
    I talked to the guys at TURBOSMART and they told me to re-route everything, because for some reason it makes the wastegate stay shut in-definately so you build up full potential boost every time.
  13. #13
    06 MS6/03.5 MSP
    Join Date
    Jul 2006
    Location
    Posts
    709
    i don't even have an mbc hooked up and it goes that high though. im trying to get it into mazda this way they can fix the problem, then i get the new wastegate after lol.
  14. #14
    Donated: $50
    Ti MSP
    Join Date
    Jun 2006
    Location
    Knoxville, TN
    Posts
    2,446
    Oh, wow.
    Yeah, sounds like wastegate is bad.
    So you took the MBC off? It still spikes?
  15. #15
    06 MS6/03.5 MSP
    Join Date
    Jul 2006
    Location
    Posts
    709
    spikes, not sure. it just f*ck*ng climbs as high as it wants, pretty much running off what the turbo is able to push, once you floor it the turbo spools so fast that once it actually starts to climb fast i let off and i usually catch it by about 15psi, but it has hit 20 or so so far. im surprised i didn't leave the bottom end on that road, scared me for a second. then i kept on messing around with different instances and nothing has worked. the sr20 6psi atp wg is probably what ill put in, i hear with some mods that on our cars it actually sits about 8psi or so which is good, that's about all i want this car to be at.
Similar Threads
  1. Boost gauge source....wastegate line??
    By GreySpeed in forum Mazdaspeed Protege
    Last Post: 01-30-2006, 08:52 AM
  2. Vacuum line to the wastegate???
    By FSDET in forum Mazdaspeed Protege
    Last Post: 07-23-2004, 10:10 AM
  3. Vacuum line to the wastegate???
    Last Post: 07-18-2004, 09:35 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
