Does anyone know where I can buy oil filters in bulk?
I know these filters work for the mazdaspeed 3, but is that wrench the right one?
Worked for me. Nice snug fit.
Only the Speed3 takes 6 quarts (or 5.7, I think)
It really isnt once you neatly widen that service hole, it will allow you to change the oil and filter without having to take off the bottom plastic cover.
9/29/07: Another note, it's recommended to replace the crush washer on the drain plug. It's an aluminum washer that is apparently only good for one tightening. The drain plug doesn't have a built in rubber washer like other cars. These can be had from the dealer's parts department also. They rip you off on them, so I'm going to see about finding another source for these. A fair price would be about a quarter each, not the dollar something the dealer charges.
Get the wrench from Mazda. Below is were I got mine. The kit is a great deal but the washers seam high. I bought them anyway so I know I'm getting all my oil change parts from mazda and will not have to worry about warranty issues. These parts are from the same dealer.
http://www.mazdaparts.org/genuine-mazda-oilfilter.html
http://www.mazdaparts.org/mazda-oil-pan-drain-plug-washer.html
The reason the new green O-rings seem smaller is that they swell a bit with use so the used ones are bigger. This is a real good reason why they should be replaced with every filter change.The aluminum gasket for the oil drain bolt is available in a bulk pack of 5 - Genuine Mazda # 99564-1400.
You may find nylon washers in the same size that would be cheaper and reusable each oil change.
The other thing I noticed was that the green "o" rings (large and small) supplied with filters are a little smaller than originals.
You can also use a Ford filter kit (ZZCA-23-802) in the 2.3L engine.
The filter cartridge in the container is spring loaded and must be pushed up to engage the threads in the oil filter housing.
The most time consuming part of the whole procedure is the removal and re-installation of the engine splash pan. (dunno)
Why would carmax change the oil? It was probably done by the previous owner. If you didn't get the service records with the car, you should probably change it, just to make sure it is done right and can start your change intervel on your own schedule. If you did get the records, they should say what oil was put in and if it is a Mazda dealer, they probably used the correct filter & o-rings (unless they didn't of course).I just bought my used speed3 about a week ago from carmax and after hearing about all these o-rings and washers needing to be replaced do you think I should change my oil again so I know it was done right? Or should I just trust that carmax did a good job changing the oil when they certified it. All these horror stories of dealerships and oil changes are scaring me!
Hmm. Okay I've heard enough warning here and elsewhere. I'm going to return my oil wrench and FRAM filter to the auto store and swing by the local mazda dealer to pick up the OEM stuff. If they're asking too much there, I'll just buy this deal online:
