the way i did my measurements was
take a rule ( i used a metal one very precise) put the trans in N
lay the ruler on the top of the stick shift so it is flat
now slide the ruler till it hits the dash
hold the ruler still mark wear N is
and shift from N to 3rd now mark it
and then do the same for 4th
then compare them to my measurements
I'm not saying mine is the best
just cheaper $
but not in the quality
Stock: 1st Gear: 4 3/8"------------2nd Gear: 8 1/4"---------Distance: 3 7/8"
-TWM: 1st Gear: 4 7/8"-------2nd Gear: 7 15/16"---Distance: 3 1/16"
Stock: 2nd Gear: 8 1/4"----------3rd Gear: 4 5/16"--------Distance: 3 15/16"
-TWM: 2nd Gear: 7 15/16"---3rd Gear: 4 13/16"----Distance: 3 1/8"
Stock: 3rd Gear: 4 5/16"---------4th Gear: 8 3/8"----------Distance: 4 1/16"
-TWM: 3rd Gear: 4 13/16"---4th Gear: 8"-----------Distance: 3 3/16"
Stock: 4th Gear: 8 3/8"---------5th Gear: 4 1/2"----------Distance: 3 7/8"
-TWM: 4th Gear: 8"----------5th Gear: 5"------------Distance: 3"
Stock: 5th Gear: 4 1/2"---------6th Gear: 8 5/16"--------Distance: 3 13/16"
-TWM: 5th Gear: 5"----------6th Gear: 8 1/16"-----Distance: 3 1/16"
