Hey all,
My P5 has a new problem. From time to time while driving I will experience what I guess can be described as a momentary loss of horsepower. If I would either let up on the gas or floor it for a second it would clear up. The car would drive fine but the check engine light would come on for a couple of days than go out. The other day I was driving and the same happened again only the power loss didnt go away after a second it kept up (I was blocked in the fast lane nobody would let me over!)And I was maxing out at about 40MPH floored in 4th gear. When I got to pull over the car sounded like it was running (barely) on 2 cylinders. I turned it off and sat there for a second. When I turned the car back on it was fine except the light was back on. I had the code read and the only code I got was that there was an engine misfire. So knowing there could be anyone of a million things wrong with it I figured I would ask and see if anyone else has experienced this.
