Mods list
SeR_Cyclops
Mazdaspeed Protege
so i was planning on running this set up anything i should do different?
AEM cai (installed)
hiboost fmic w/pipes
greddy type s
greddy turbotimer (installed)
greddy profec b
Autometer boost gauge (installed)
apexi 3inch tbe or cut outs? i like the idea of off and on.
corksport S pipe
wrx 440 injectors
split second psc 1
solid front motor mount
kartboy shifter bushings
kartboy exhaust hangers
looks good. You might wanna add wb02 and egt gauges to the list though.
How much boost you planning to run and will the split second be the one with timing retard built in? Your timing will be advanced from leaning the increased richness fuel ratio from the 440's. Make sure you have an experienced tuner help you out. Let me know hot it works. I have some 440's in my garage and I'm debating putting them in for a tune.
s6m1l88 said:
Is it just me, or... what did you just say? (ugh)(smoke)
Wow. Thanks for pointing that out. What I meant to say was: Since the 440's will be pushing a lot more fuel you will have to tune to lean it out. A by product of this is advanced timing. I inquired at a local tuner about doing this mod myself and he said that was one of the risks. You know what nevermind. I can't think or talk straight lately. Maybe becuz its been under 5 degrees fahrenheit here in MN for the last 10 days.
Oh yeah and definately take care of welding replacing your LSD...it will break if it hasnt already...the quaife is beautiful but costly...I have the welded one from PG and it is holding up very well.
Latest posts
