filter restore kit?
C'ville said:
I think the restore kit is to clean and re-oil your filter.
(iagree) - the filter is a reusable type you wash with soap and water (or whatever method the owners manual says to do) and then you must re-oil before installing as it uses the oil to aid in filtering...
Be carefull you dont over oil the filter when restoring it as it can foul your air mass sensor and trigger a dreaded CEL code...
