www.cp-e.com
jdub260 said:OK here is what I consider some good questions for cp-e.
Can the AWD distribution be manually controlled through this system or something similar? From what I know the AWD system is controlled by the computer.
Can this system be set up to automatically turn the DSC off? I hate having an electronic baby sitter, if I want it I should have to turn it on.
Those are good questions! Unfortunately we are unable to perform either of the operations you mention with our piggyback. You can basically think of a piggyback tuner as a signal conditioner. We can tap into any sensor and alter the signal sent to the ECU in order to change engine operation parameters from its stock configuration. Since the AWD system is heavily reliant on sensors (eg. wheel speed and steering angle) we could lie to the AWD system, but I'm can't come up with a scenario in my head where this would be beneficial? Maybe you can fill me in on what you're considering. But since the DSC system isn't exactly a sensor, we can't do much to change its default setting.
We actually ran into some issues last week with the fuel cut. It turns out that there's a lot more that goes into the fuel cut initiation than just the MAP sensor input. So, we wrestled with the SPEED6 for a while and were able to get it to do what we wanted it to, but we had to be clever about it (I'll explain in detail later). We're going to schedule a dyno for next week so we can create an optimized map for stock SPEED6's, and we'll start distributing our piggyback to beta testers soon as well. Stay tuned guys, there's a lot more to come!
Jordan
