VersaTuner - tuning software for Mazdas
Results 1 to 6 of 6
Thread: gas cap issue is now finally a recall
  1. #1
    手前の言葉が俺は聞き捨てよう TheMAN's Avatar
    Join Date
    Oct 2002
    Location
    Dallas, TX
    Posts
    5,853
    TSB: 01-001/07
    2007 CX-7, 2006-2007 MX-5, 2006-2007 RX-8 - MAZDA SPECIAL PROGRAM (MSP13) - MIL ILLUMINATION WITH DTC P0455
    APPLICABLE MODEL(S)/VINS
    2007 CX-7 vehicles with VIN JM3ER29**70100057 - JM3ER29**70128616 (built from February 14, 2006 through August 1, 2006)
    2006-2007 MX-5 vehicles with VIN JM1NC**F*60111723 - JM1NC**F*70125568 (built from January 6, 2006 through August 2, 2006)
    2006-2007 RX-8 vehicles with VIN JM1FE173*60200012 - JM1FE173*70208462 (built from January 7, 2006 through August 2, 2006)
    DESCRIPTION
    It is possible that a malfunction indicator light may illuminate with DTC P0455 (EVAP System Leak Detected-Large Leak) stored in memory, due to poor sealing between the fuel filler pipe and fuel filler cap.
    NOTE:
    • UNDER THE MAZDA SERVICE PROGRAM (MSP13), ALL CURRENT DEALER INVENTORY AND RETAILED VEHICLES FOUND TO BE WITHIN THE ABOVE PRODUCTION AND VIN RANGES MUST BE INSPECTED AND REPAIRED ACCORDING TO THE INSTRUCTIONS CONTAINED IN THIS SERVICE BULLETIN. THIS INCLUDES CUSTOMERS WHO HAVE BROUGHT THEIR VEHICLE IN FOR NORMAL SCHEDULED MAINTENANCE AND/OR OTHER SERVICE WORK THAT MAY NOT BE RELATED TO THE CONCERNS OUTLINED IN THIS BULLETIN.
    • BEFORE PERFORMING ANY REPAIR, VALIDATE THAT THE VEHICLE IS APPLICABLE TO THIS PROGRAM BY PERFORMING AN "eMDCS" WARRANTY VEHICLE INQUIRY "AND VERIFYING THE VEHICLE DISPLAYS CAMPAIGN "MSP13" AND ITS CAMPAIGN STATUS DISPLAYS "OPEN". SEE "VEHICLE INSPECTION PROCEDURE" BELOW.
    DEALER INVENTORY:
    Repair all applicable vehicles currently in dealer inventory according to the procedures contained in this service bulletin.
    RETAIL VEHICLES:
    When an applicable retail vehicle is brought into the dealer for any type of repair or scheduled maintenance, perform an eMDCS Warranty Vehicle Inquiry and check the status of MSP13. If status of MSP13 is "OPEN", repair the vehicle according to the procedures contained in this service bulletin.
    1. Verify the vehicle is within the following production and VIN ranges:
    • 2007 CX-7 vehicles built from February 14, 2006 through August 1, 2006
      • VIN Range: JM3ER29**70100057 - JM3ER29**70128616
    • 2006-2007 MX-5 vehicles built from January 6, 2006 through August 2, 2006
      • VIN Range: JM1NC**F*60111723 - JM1NC**F*70125568
    • 2006-2007 RX-8 vehicles built from January 7, 2006 through August 2, 2006
      • VIN Range: JM1FE173*60200012 - JM1FE173*70208462
    • If the vehicle is within the above Production and VIN ranges, proceed to Step 2.
    • If the vehicle is not within the above Production and VIN ranges, return the vehicle to the customer or inventory.
    2. Perform a Warranty Vehicle Inquiry using your eMDCS System and inspect the vehicle for a Campaign Label MSP13 attached to the vehicle’s bulkhead. Refer to eMDCS System - Warranty Vehicle Inquiry Results table below. NOTE: Verify the campaign number as the vehicle may have multiple labels.
    If eMDCS displays:
    Campaign Label is:
    Action Required:
    "Campaign: MSP13 Open"
    Present
    Contact the Mazda Corporate Dealer Assistance Group at (877) 727-6626 to update vehicle history
    Not present
    Proceed to "REPAIR PROCEDURE"
    "Campaign: MSP13 Closed"
    Present
    Return vehicle to inventory or customer
    Not present
    Complete a label and apply it to vehicle’s bulkhead
    "Campaign: MSP13 Open" or "Closed" is not displayed
    Does not apply
    Campaign does not apply to this vehicle. Return the vehicle to inventory or customer
    REPAIR PROCEDURE
    1. Verify customer concern.
    2. Replace fuel filler cap with a modified one.
    3. Fill out a blue "Campaign Label" (9999-95-065A-05) with the Campaign No: "MSP13", your dealer code, today’s date, and affix it to the vehicle’s bulkhead.
    4. Verify repair.
    5. Return the vehicle to the customer.
    PART(S) INFORMATION
    Part Number
    Description
    Qty.
    Notes
    FEY2-42-250
    Fuel Filler Cap
    1
    WARRANTY INFORMATION
    NOTE:
    • This warranty information applies only to verified customer complaints on vehicles eligible for warranty repair. Refer to the Warranty Wizard for warranty term information.
    • Repairs performed outside the New Vehicle Limited Warranty will require DCSM or DSA authorization.
    • Additional diagnostic time cannot be claimed for this repair.
    Warranty Type
    A
    Symptom Code
    99
    Damage Code
    99
    Process Number
    A0685A
    Part Number Main Cause
    FEY2-42-250
    Quantity
    1
    Operation Number / Labor Hours
    XXB493RX / 0.2 Hrs.
    TheMAN
    '01 BJFP MT
    '05 BK3P HB AT
    '16 BMYFS AT
    For Protege and Mazda3 info, come see the Protege FAQ
  2. #2
    Registered Member CX-7 ZOOM-ZOOM's Avatar
    2007 Mazda CX-7
    Join Date
    Dec 2006
    Location
    Lynnwood,Washington
    Posts
    13
    Thanks I got my CX-7 on Dec 28th and 3 days and 200 miles my CEL came on and this is what it was so they replaced my gas cap and did a few other software updates that had codes as well.
    Thanks,
    Shawn
  3. #3
    CX7 Freak Shaz's Avatar
    Mazda CX7 GT AWD Electric Blue
    Join Date
    Jan 2007
    Location
    North Aurora, IL
    Posts
    600
    I got mine dec 28th as well and has 277 miles on it. I haven't seen any warnings yet on the dashboard but I was already aware of this issue so when I had a fill-up, i made sure I closed it tight. I am still having it inspected when I bring "The Beast" for a quality care inspection. Thanks for the heads-up
  4. #4
    Proud New CX-7 Owner! CXRabbit's Avatar
    2009 CX-9 TR +Kenwood DNX7020EX
    Join Date
    Nov 2006
    Location
    Long Island, NY
    Posts
    569
    I asked for the new gas cap before taking delivery (picked it up the end of November)
    ~Amy
  5. #5
    Registered Member spike blue's Avatar
    2007 mazda CX-7,Kia sephia 2006 Audi A4 Sline
    Join Date
    Feb 2004
    Location
    sunrise and orlando ,south florida
    Posts
    1,736
    16500 miles on mine right now and now gas cap issue and no hesitation issue , but i did flashed and i feel the big difference now!!
    currents cars:
    2007 infiniti G35 sedan MINE
    2008 audi A4 Sline(silver) MY BROTHER
    2007 mazda CX-7(liquid platinium metallic)MY DAD
    1998 Kia sephia LX (black)LOL the emergency
    Previous:
    2003.5 Mazdaspeed protege(2409) i missed so
  6. #6
    Registered Member
    07 Mazda CX-7, 98 626
    Join Date
    Dec 2006
    Location
    Wichita, KS
    Posts
    5
    gas cap replaced
    I got mine replaced at about 2700 miles when I got the light. They had just gotten a batch of the new caps in and said that, though it wasn't technically a recall issue at the time, they had been directed to replace them anytime somebody brought their car in with the problem.
Similar Threads
  1. CEL and Gas Cap Issue
    By boytoys in forum Mazda5 Engine & Transmission
    Last Post: 04-13-2007, 09:34 PM
  2. Finally figured out the issue
    By I_Vtec in forum Global
    Last Post: 02-28-2006, 05:30 PM
  3. What type of gas do you have?
    By chrisjw85 in forum Mazdaspeed Protege
    Last Post: 03-06-2005, 07:14 AM
  4. Where do you put your gas cap when filling up?
    By funnylittlman in forum Lounge
    Last Post: 09-02-2003, 10:12 AM
  5. sub installed (cap question?)
    By traitorhound in forum Mazda How-To
    Last Post: 06-05-2003, 08:58 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
