VersaTuner - tuning software for Mazdas
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 61 to 75 of 83
Thread: Mazdaspeed OEM Wastegate actuator = $$$$$$$$
  1. #61
    Registered Member bwlknsn91's Avatar
    2003 MSP Black Mica #117
    Join Date
    Apr 2012
    Location
    St. Louis, MO
    Posts
    368
    Quote Originally Posted by orng1 View Post
    I found it easier to just remove the turbo/manifold as an assembly.
    I am just curious as to how the WGA is actually connected onto the turbo. A few bolts I'm assuming?
  2. #62
    Registered Member mebarsh's Avatar
    03.5 msp #215
    Join Date
    Sep 2006
    Location
    va beach
    Posts
    274
    Yeah its just two small nuts and the clip holding it on. I did it without taking the turbo off the car but it was a pain to do.
    2003.5 titanium msp: mam fmic, relocated maf, type 9 bov, dual display afr/boost gauge, instrument cluster single gauge pod, Dave b gauge rings, twm m1 abrams shift knob, 20% tint, D2 coilovers,6k hids, purple dress up bolts, Su front mount, exedy stage 1 clutch. Turbosmart boost controller, removed cats, 15mm front 8mm rear spacers, ssafc (custom tune), rsx radiator, 12" slim fans, weapon r coolant overflow tank.
  3. #63
    I break stuff. Preferio's Avatar
    Donated: $1.67
    2003 Mazdaspeed Protege 1660, 2004 Winning Blue RX8, 2005 Mazda6
    Join Date
    Mar 2011
    Location
    Knoxville, Tn
    Posts
    3,819
    Quote Originally Posted by mebarsh View Post
    There's no way I'd try it with the turbo on the car... I had to take mine off to put a new gasket on Monday and I had it off and back on in an hour, so I don't see why you wouldn't just take it off.
    ASE Certifications: A1, A4, A5, A8, C1, P2
    Mitsubishi-Fuso: Electr. Cert. 1, 2, 3 and 4
    2013 Mazda CX5 Touring
    2008 Mazda CX7 Touring
    2007 Mazdaspeed 3:
    2005 Mazda 6 S: Gone.
    2004 Mazda RX8: Gone.
    2003 Mazdaspeed Protege #1660: Gone and missed.
    2003 Mazda Protege5: Gone.
    2002 Mazda Protege5: Gone.
    1995 Mazda Miata Best $50 I've ever spent.
  4. #64
    03.5 msp #215
    Join Date
    Sep 2006
    Location
    va beach
    Posts
    274
    Didn't wana deal with coolant. I hate coolant with a passion. I would say it took me about an hour to replace it with it still on the car. All I did was unbolt the manifold from the block and pull it out a little so I had enough space to work back there.
  5. #65
    Join Date
    Apr 2012
    Location
    St. Louis, MO
    Posts
    368
    Coolant from where? Lol I am still in the process of learning all this stuff!
  6. #66
    Donated: $1.67
    Join Date
    Mar 2011
    Location
    Knoxville, Tn
    Posts
    3,819
    Quote Originally Posted by bwlknsn91 View Post
    The turbo is oil and water cooled. The steel tubes coming from the turbo are the coolant lines and the braided one is the oil line.
  7. #67
    Join Date
    Apr 2012
    Location
    St. Louis, MO
    Posts
    368
    Ah! So if I were to remove the turbo, what would I have to do about the coolant? Also, if the WGA is connected to the turbo would it come out attached when I remove it?
  8. #68
    Donated: $1.67
    Join Date
    Mar 2011
    Location
    Knoxville, Tn
    Posts
    3,819
    Drain it... Yes.
  9. #69
    03.5 msp #215
    Join Date
    Sep 2006
    Location
    va beach
    Posts
    274
    There's a drain plug on the bottom of your radiator. Your still gona have some coolant come out when you take it apart tho.
  10. #70
    Join Date
    Apr 2012
    Location
    St. Louis, MO
    Posts
    368
    Awesome! Thanks guys, I appreciate all the help! But just to double check, when I remove the turbo, the WGA will come out with it?
  11. #71
    Donated: $1.67
    Join Date
    Mar 2011
    Location
    Knoxville, Tn
    Posts
    3,819
    Yes. It has two 10mm nuts and a retaining clip at the wastegate itself.
    To remove the manifold you're going to need...
    10mm socket/box end- (manifold heatshield/wastegate actuator/condensor fan assembly)
    12mm socket (manifold studs/nuts)
    12mm box end (manifold studs/nuts)
    6mm allen (coolant/oil lines clamp)
    14mm socket (j-pipe to s-pipe nuts)
    6" extension
    pliers (clamps for hoses assuming they're the factory clamps)
    PB Blaster (or other penetrating oil)
  12. #72
    Join Date
    Apr 2012
    Location
    St. Louis, MO
    Posts
    368
    Quote Originally Posted by Preferio View Post
    6" extension
    Wow, this seems a lot more complicated then I expected! Especially since I am unexperienced with this kinda stuff! Lol
  13. #73
    Donated: $1.67
    Join Date
    Mar 2011
    Location
    Knoxville, Tn
    Posts
    3,819
    It's really easy actually. I'm just giving you the list so you know exactly what you need. I've had the manifold off a dozen times and the engine out almost as many on these cars and like I said, I can remove it and reinstall it in an hour. Even being unexperienced, I would imagine this wouldn't take more than two hours. The tools I lised come in even the most basic tool sets.
  14. #74
    Garage Queen Spiced MSP's Avatar
    2016 Peterbilt 579
    Join Date
    Feb 2009
    Location
    Columbia, SC
    Posts
    3,678
    click --> http://www.mazdas247.com/forum/showt...tegate+install
    everyone uses different methods. This might give you a little bit of a visual aid.
    RIP 1549 spicy totaled...
    2006 Toyota Tundra Limited Double Cab- No longer have
    Current Vehicle: 2016 Peterbilt 579 10 speed Eaton Fuller...lol. At least I get to still hear something spool up
  15. #75
    Donated: $1.67
    Join Date
    Mar 2011
    Location
    Knoxville, Tn
    Posts
    3,819
    Quote Originally Posted by Spiced MSP View Post
    I'm glad you posted that for him, because I forgot about the EGR pipe. 1 1/16" for it.
Similar Threads
  1. Mazdaspeed OEM Exhaust Question
    By jrodhotrod in forum Mazdaspeed Protege
    Last Post: 03-03-2004, 12:51 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
