Compare auto reliability with reliable results at TrueDelta.com!
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 46 to 60 of 83
Thread: Mazdaspeed OEM Wastegate actuator = $$$$$$$$
  1. #46
    Registered Member kneedragger89's Avatar
    Mazdaspeed Protege
    Join Date
    Nov 2009
    Posts
    60
    Do not buy the forge wga.
  2. #47
    cheif smacktalker yudkib's Avatar
    Join Date
    Mar 2009
    Location
    hartford ct
    Posts
    4,598
    sounds like someone has an experience to share?
    neither the forge nor the ATP is as good as OEM, but as stated, the prices are ludicrious.
    titanium #129 - sold.
    "What do I think of success? It sucks, too much press, I'm stressed - Too much stares, two breasts, too upset. It's just too much mess. I guess I musta blew up quick, grew up quick, was raised right. Whatever you say is wrong, whatever I say is right"
  3. #48
    U8RICE MSP-2003.5's Avatar
    2003.5 MSP
    Join Date
    Apr 2010
    Location
    Louisville
    Posts
    406
    The stock WGA is a piece of crap, mine went bad at 30k miles. I now have 40k on my forge wga and it is still working like a charm
  4. #49
    147 to the wheels bitches destineal's Avatar
    Donated: $1.29
    The Procrastinator
    2003 Mazdaspeed Protege Black Mica #129
    Join Date
    Nov 2009
    Location
    Fayetteville, Georgia
    Posts
    3,057
    ATP here I come.
    Quote Originally Posted by Wagonbacker9
    no point in looking for unknown problems when you have known ones...
  5. #50
    Donated: $1.29
    The Procrastinator
    Join Date
    Nov 2009
    Location
    Posts
    3,057
    This e-clip is a S.O.B. and I want to fight it.
  6. #51
    Registered Member steedspeed's Avatar
    Join Date
    Jul 2007
    Posts
    208
    Nothing oem is worth the money. Their replacement turbo manifold is over $1000 for a cheap shit casting. BTW you are always better off spending money on tools rather than mechanics. Buy the tools and learn how to do stuff yourself because it isnt that hard.
    "Imagination is more important than knowledge." Albert Einstein.
  7. #52
    Donated: $1.29
    The Procrastinator
    Join Date
    Nov 2009
    Location
    Posts
    3,057
    Well I just finished the ATP WGA install.I still have my idle issues. Gonna go get some vacuum hoses to see how that goes. I dunno if the new WGA is bad or what. Peaks at 9-10psi and settles at 6psi..feels stronger though.
  8. #53
    2003.5 MSP
    Join Date
    Apr 2010
    Location
    Louisville
    Posts
    406
    any fuel cut after replacing the WGA? did you get the forge WGA? it has different selection of springs that may alter your spike
  9. #54
    Donated: $1.29
    The Procrastinator
    Join Date
    Nov 2009
    Location
    Posts
    3,057
    Me? I got the ATP WGA, but I have some underlying issues going on vacuum related i think.
  10. #55
    Registered Member bwlknsn91's Avatar
    2003 MSP Black Mica #117
    Join Date
    Apr 2012
    Location
    St. Louis, MO
    Posts
    368
    I am currently thinking about purchasing the ATP wastegate for my 2003 MSP and plan on doing the replacement myself. Are there any detailed pictures/descriptions I can use to make this as easy as possible? After reading the How-To already posted, I am still nervous about doing it since I have minimal experience. Thanks for help!
  11. #56
    Msp 666 Aka Christine mazdaspeedp's Avatar
    Donated: $10
    2003.5 Mazdaspeed Protege
    Join Date
    Oct 2008
    Location
    Calgary, Alberta Canada
    Posts
    2,453
    I have an atp running for last 50000 kms still doing good.
    motor build in progress. Weisco and Pauter Forged rods and pistons .9mm overbore 9:1 compression. Perrin fuel system and Doc B oil system. New motor mounts by AWR. And new oilpan by AWR. Spec stage 3+ clutch and factory flywheel,Rebuilt cylinder head with FS-ZE cams. Haltech standalone platinum 1000 with Custom patch harness.505 Intake manifold,Steedspeed exhaust manifold with CS Turbo back exhaust system custom fitted and modified cs S pipe, Garrett gtx2867 turbo, custom Fmic setup with Hks ssqv bov, deuchworks fuel pump, Id1000 injectors, Personal steering wheel and hub,GT Spec suspension parts,Mishimoto Radiator with slim fans and Mishi fan shroud,Irradium catch can,bandm oilcooler.Hydra transmission brace plate. Innovative wideband, haltech boost controll solenoid.
  12. #57
    Join Date
    Apr 2012
    Location
    St. Louis, MO
    Posts
    368
    Bump! Any suggestions guys?
  13. #58
    Registered Member orng1's Avatar
    mazdaspeed protege
    Join Date
    Dec 2003
    Location
    Los Angeles
    Posts
    3,255
    Just be careful not to lose the c clip. It's tiny, hard to see when you drop it. Which I have a few times..
  14. #59
    Join Date
    Apr 2012
    Location
    St. Louis, MO
    Posts
    368
    Thank you sir! Just trying to get familiar with what actually needs to be done to remove the wastegate actuator as well as replacing it (besides removing the necessary parts to reach it).
  15. #60
    mazdaspeed protege
    Join Date
    Dec 2003
    Location
    Los Angeles
    Posts
    3,255
    I found it easier to just remove the turbo/manifold as an assembly.
Similar Threads
  1. Mazdaspeed OEM Exhaust Question
    By jrodhotrod in forum Mazdaspeed Protege
    Last Post: 03-03-2004, 12:51 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
