In Memory of Member 1338
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 16 to 30 of 83
Thread: Mazdaspeed OEM Wastegate actuator = $$$$$$$$
  1. #16
    Registered Member Blackrose's Avatar
    2007 Subaru Legacy GT 2006 Evo IX
    Join Date
    Sep 2004
    Location
    Highland In.
    Posts
    832
    Rouge who coated your mani and DP and how long has it been like that?
  2. #17
    I gots SPICE jmv's Avatar
    2003 MSP #1475
    Join Date
    Oct 2005
    Location
    San Antonio, TX
    Posts
    2,321
    Quote Originally Posted by TheMAN
    because it's NOT the same!
    its just like brake pads... people think brakes are brakes and just get the $20 autozone SHIT instead of paying $100 for OEM brake pads from the dealer
    right, they are not the same because the stock piece is adjustable.... but if they hold very close to the same boost and serve the same purpose, and both are able to be bolted right in, is there really that much problem with going with the cheaper one?? I guess its personal opinion, but it wasn't a super big deal to me. I guess YMMV.
  3. #18
    Quote Originally Posted by jmv
    I'd say typically the OEM one would probably be of better quality, but well with how unreliable people's wastegate actuators have been.. ugh
  4. #19
    世界杯 Allen's Avatar
    Donated: $30
    2003.5 MSP
    Join Date
    Feb 2002
    Location
    San Diego, CA
    Posts
    551
    Yeah, OEM is about 7x the cost of aftermarket... unfortunately, it's not pocket change for me. So, hopefully the ATP isn't crap! Seeing how several folks (knowledgeable ones too) have used it, I feel better taking that risk myself. I should be able to find someone good with cars to help me install it.
    Great, now it looks like it's going to get a bit nippy here in Texas... grrrr.
    Almost stock. Gotta keep this car rolling!
  5. #20
    ATP seems like a great all-around vendor, they have a nice selection of parts.
  6. #21
    Registered Member orng1's Avatar
    mazdaspeed protege
    Join Date
    Dec 2003
    Location
    Los Angeles
    Posts
    3,255
    I see how it could be argued that the OEM piece is better because it's adjustable but if you set it to 6-7psi then your just spending money. I think that's what most people would want their low boost to be anyways so I'd save the money and go for the cheaper one. IF you set it too high or too low you'd have to take the thing off and set it up again, you know where you stand with the ATP.
  7. #22
    2003 MSP #1475
    Join Date
    Oct 2005
    Location
    San Antonio, TX
    Posts
    2,321
    Quote Originally Posted by Allen
    hey if you're near austin i could always help.....
  8. #23
    In memory of 1244 Pmpkinhead's Avatar
    Donated: $20
    '03.5 Blazin' MSP (sold) ................. '14 Soul 6 GT
    Join Date
    Mar 2003
    Location
    Cleveland
    Posts
    1,277
    Blog Entries
    1
    My car started hesitating under WOT at 3000-4000 RPM. I took it in today and the dealer is putting in a new WGA!!! (warranty) I thought it was bad gas. I have no engine mods except Firsty's Grounding Kit and a Yellow Top Optima with Custom Alum Battery Cage from E-Bay. I never heard of a WGA until this thread started. Thanks Mazda Forums.
    367 (mp3yellow
  9. #24
    Registered Member Sspring89's Avatar
    MazdaSpeed Protege
    Join Date
    Nov 2006
    Location
    Orlando
    Posts
    89
    So, how exactly do you adjust the stock WGA? is there just a screw to up the boost, say, 1 psi?
  10. #25
    Quote Originally Posted by Sspring89
    well not reeeally. All you are adjusting is the length of it. If you tighten it, theoretically it'll take more boost to actuate it fully depending on how the stock actuator is.
    Actually wait no.. no matter what your wastegate actuator should be open fully by 5.5-6.5 psi (don't know what stock msp is) so if you tighten it to let it boost a little higher, it'll just take longer to open. yeah just get a manual boost controller. Much easier, more precise, etc.
  11. #26
    mazdaspeed protege
    Join Date
    Dec 2003
    Location
    Los Angeles
    Posts
    3,255
    That is a much better option, boost controler. It would be too much of a pain in the a to keep taking the actuator off just to get a pound extra or less. I have a MBC and I just set it up higher lower it just takes a few seconds.
  12. #27
    手前の言葉が俺は聞き捨てよう TheMAN's Avatar
    Join Date
    Oct 2002
    Location
    Dallas, TX
    Posts
    5,839
    the OEM one just doesn't bolt right in... you have to adjust it to the proper length first before installing it, then testing to see if it's building the correct stock boost... which wouldn't be the same on all setups on a given same length due to manufacturing variations on all sorts of parts... the OEM shit is NOT pre-adjusted to the correct length from the factory!
    TheMAN
    '01 BJFP MT
    '05 BK3P HB AT
    '16 BMYFS AT
    For Protege and Mazda3 info, come see the Protege FAQ
  13. #28
    Join Date
    Oct 2002
    Location
    Dallas, TX
    Posts
    5,839
    Quote Originally Posted by Kansei
    the fact that the original ones have been breaking on some people's cars is why mazda came out with an updated part, which shouldn't have problems like the original ones did
  14. #29
    2003 MSP #1475
    Join Date
    Oct 2005
    Location
    San Antonio, TX
    Posts
    2,321
    thats true. Didn't really think about that. Well, from what i had read about the ATP some people said they saw about 2 psi increase, which i thought might be a little on the high side but still okay. Turns out when i got it it really only put me up 1 psi from when i was bone stock, which to me is just fine. The car feels like maybe it takes just a little more gas to build boost, but that could just be mind tricks from going from the leaking diagprham to a good one.
    BTW Edwin, i'm not just trying to straight up disagree with you or anything, just pointing out how this seemed to be the best option for me given the cost.
  15. #30
    AFCed Since 8/25/07 Alejo_NIN's Avatar
    RadonElement.Com
    Join Date
    Jun 2005
    Location
    Miami Lakes, FL
    Posts
    4,912
    i thought i wrote a how to on replacing the atp wastegate...hmm....
    MODS?!?!
    oh wait, is on my sig
Similar Threads
  1. Mazdaspeed OEM Exhaust Question
    By jrodhotrod in forum Mazdaspeed Protege
    Last Post: 03-03-2004, 12:51 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
