Just a quick question, that has come to mind, and want to make sure I am thinking clearly on this.
If you have the automatic transmission in fully automatic mode, and then decide you want to switch to say a lower gear manually, as oppossed to say dropping the pedal to make it downshift, could you move the gear selector while traveling, to the select mode, and then paddle down?, or do you have to make this selection before car is moving, on how you want to handle the shifting the car.
Thanks Stay safe
Thanks Stay safe
