Mazdaspeed6 Rims
ms64meplease said:
ebay right now at 750 buy now so thats 50 bucks less i wont go anylower than what on ebay if they dont sell at this price then looks like i just have a spare for those crapy days
Here's the eBay listing ... $745 is a pretty good deal imho:
https://www.ebay.com (commissions earned)
You are bidding on a set of FOUR factory new 2006 Mazda Mazdaspeed 6 original equipment Tires and Wheels package.
Removed immediately after purchase, with only 271 miles on the car. There are NO scratches or hidden damage.
This package retails for nearly $2,000 and includes:
Four OEM Mazdaspeed6 Rims ($1,000 value)
Four Bridgestone Potenza RE050A, 215/45/ZR18 tires ($796 value)
Mounted and Balanced ($100 value)
Factory lug nut kit with security lugs and key ($40 value)
http://www.tirerack.com/tires/tires...ed_rating=WR&speed_rating=YR&minSpeedRating=V
The Potenza RE050A is a Max Performance Summer tire designed to complement the performance of sports cars, sports coupes and sport sedans. While the Potenza RE050 is used as Original Equipment on the supercharged Mercedes-Benz S55 AMG sedan, a Potenza RE050A Scuderia version is used on the 12-cylinder Enzo Ferrari supercar, and a Run Flat version is used on the BMW Z4 sports cars and 5-Series sedans. The Potenza RE050A was developed to provide good traction along with responsive and predictable dry and wet road handling. It is not intended to be driven in near-freezing temperatures, through snow or on ice.
On the outside, the Potenza RE050A features a high grip tread compound molded into an asymmetric tread design. A continuous center rib, large tread blocks and stable shoulder elements provide responsive handling, high-speed stability and traction on dry roads, while circumferential and lateral tread grooves are aimed to pump water out from under the tire's footprint to minimize hydroplaning and aid wet traction. A continuous circumferential rib adjacent to the inside shoulder blocks enhances wear quality to help reduce noise throughout the life of the tire, especially on cars with alignment settings that specify negative camber. Internally, the Potenza RE050A features twin steel belts reinforced by spiral-wrapped nylon to stabilize the tread area and enhance handling, high speed capability and ride quality while minimizing weight. The fabric cord body and hard rubber sidewall filler help blend uniform ride quality with steering response and lateral stability.
Next Day FedEx ground shipping. Tracking Number will be provided.
Bid with confidence!
