Hello, I need help on my protege 1994. The problem started during the heat wave in California. During heat wave I notice that my temperature has gone up. Upon investigation, I notice that my second radiator fan is not working and has not been working ever since. The BIG radiator is working and can handle things before the heat wave. Anyway, I was able to troubleshoot the problem by changing the thermoswitch located at the top of the radiator. I got the thremoswitch from a pick n pull yard. The second radiator fan is working but for some reason, it turns ON only when the engine temperature is close to maximum HOT. I dont know why...is it possible the thermoswitch rating is not the correct specs for my car (i got it from the same protege but i am not sure about the year)? it there anything more to check?
Pls help and thanks !
