automatic transmission help please
you're either not pulling the e-brake hard enough or it's not adjusted properly because your car *is* rolling a bit even though you pulled the e-brake
the car is only supposed to move half an inch at the most after you pulled the e-brake and let go of everything else
but it doesn't move at all because i still have my foot on the brake pedal and that cant be the problem because im always doing it the same way and today it started acting upand sticking
rodney said:
it just sounds like it gets stuck for a second and then jerks into reverse and the wierd thing is that it will only do it when i am inclined
you have checked the ATF fluid level i assume?
try pulling the e-brake up then put the transmission in parking, then put the transmission in reverse then release the e-brake, it happens in my mom's tribute if you don't do it this way ;)
Latest posts
