Hi guys, I was driving home last night and noticed my check engine light on. When I pulled over steam was coming out of the front driver side of my protege 5. When I opened the hood the coolent was boiling and steaming in the coolent resovoir. I let my car cool for a bit, refilled the coollent and drove around the block. Immediately within half a block the temperature shot up. I pulled over and took a look and did not see any noticable leaking. The weird thing is that if the car runs at idle the temps are fine. When I drive and put it under load it heats up. So today I go back to my car, check the coolent level and its way down in the resovoir so I figure it sucking it back into the radiator. I fill it up, start the car, and at idle the temps are normal. I start to drive up the block and it looked okay other than a slight uptick on the guage. I then figure I can drive it home, so I end up turning on the heater at full blast and jumping on the freeway. On my drive home the temp shoot up depending on how much throttle I apply. Since I have a manual I coast to cool it down. This works for approx 10-15 miles. Then I get to my hometown and notice it rising again at an alarming rate. I check under the hood and the resovoir is boiling again. I've checked the radiator cap visually, upper/lower radiator hose, fan movement, areas around the resovioir and don't see anything strange. I did see fluid dripping from my car but I think that's from the boiling overflow that spewed all over. Any ideas what the problem could be? My next guess is thermostat or a clogged radiator. Sorry for the long read, Thanks for the help!
