I think it is pretty easy, no pics needed. It is adhesive only, probably. Wash car. Use rubbing alcohol on area to remove any oils that will not let the adhesive tape do its thing. Test fit to area, getting it lines up evenly. Mark the area around the deflector with pencil or other temporary marking device. Remove tape, install. press firmly, working your way out. Done. That is how I put the thing on my 86 CRX, basically.
