Hi, I've been lurking here for a while now, there is a lot of good info and nice looking p5s here.
Anyway, I have an '03 laser blue p5 and I just decided to install eibach pro-kit springs and tokico blues. The front went pretty smooth but on the back left when I put the strut together and tried to install it, the bottom and top are about an eighth of a turn out of line, when I had the top mounted in the car I had to try to turn the bottom to get the brackets to line up, I almost got together but I didn't want to put it together like that with it all bound up. I am reusing the stock rubber spring seats and bump stops, I tried to take the strut apart and put it back together, it felt like everything was lined up right but I had the same problem again. The bottom of the spring is in the perch, but I cant really tell if the top is or not.
Any help I can get is desperately needed.
Thanks
Well, it sounds pretty obvious, but I wound up taking the strut apart and putting it back together so it lined up better. The thing that confused me was that the fronts could be turned so they lined up after they were assembled but the rear ones wouldn't turn at all. When I put it together in the first place I tried to line up the marks from the old spring with the new spring in the top piece.
It's back together and drives straight, it actually rides better than it did stock.(2thumbs)
Thanks
