KrayzieFox
- 01 MP3 Turbo
Holy hell .. that does like IC in the picture.khaosman said:hahaha, do you live in Iowa City?
ChopstickHero said:put some anti-seize compound on the hub and it will prevent the wheel from sticking next time.
aMaff said:so getting new rims will scare the old ones into submission?
I've had issues w/ em after auto-x's (heat + different metals = bind), but nothing a swift kick (or 2 or 3) couldn't fix. Anyway, I think the rubber mallet would be a good ideeer, but I've never tried the water thing. Could do the trick!
Hmm. With nothing between the wheel and the hub when the lug nuts are tightened down there will be a tremendous amount of friction on that flat interface and this will take essentially all of the perpendicular load off the bolts holding the wheel on. If a perfect lubricant (no such thing obviously) was smeared across that interface first then those bolts would be taking the entire perpendicular load. Anti-seize is going to fall somewhere in between these extremes. I wonder though if it might act as enough of a lubricant to put a significant strain on the bolts? That might not be a good thing in the long run.
pasadena_commut said:Hmm. With nothing between the wheel and the hub when the lug nuts are tightened down there will be a tremendous amount of friction on that flat interface and this will take essentially all of the perpendicular load off the bolts holding the wheel on. If a perfect lubricant (no such thing obviously) was smeared across that interface first then those bolts would be taking the entire perpendicular load. Anti-seize is going to fall somewhere in between these extremes. I wonder though if it might act as enough of a lubricant to put a significant strain on the bolts? That might not be a good thing in the long run.
ChopstickHero said:I believe our wheels are hubcentric
